1st March February 2012
Latest post 04-07-2008 1:05 PM by ®. 13 replies.
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
Richard, There are several B&O documents which describe option programming, but normally with pictures showing typical configuration, however the following may be easier to understand:- Option 0 = No IR reception Option 1 = Two IR-eyes in the same main room Option 2 = One IR-eye in the main room Option 4 = Link room product connected to one or two main room products, all in the same room Option 5 = Two IR-eyes in the same link room Option 6 = One IR-eye in the link room
- Joined on 04-01-2007
- UK
- Posts 970
I am still trying to understand an explanation to a recent post I made. I have a BV1 (option6) upstairs linked to an Avant (option2) downstairs. Why would a Beo1 operate the BV1 in option 1 but the Beo4 doesnt. If Bv1 is in option 6, the Beo4 works but not the Beo1. I still would like to think it is possible to use both a Beo4 & Beo1 with the BV1.
RayTheWash
- South East London
- Posts 93
....at least you have the option to use either, my Beocentre 1 doesn't seem to support a Beo 1 at all! Regards Ray
Keith Saunders
- Posts 3,810
Ray, Your question is linked, but what I can say is that two versions of the Beocentre 1 were shipped with Beo1's and two versions with Beo4's as below:- Type 850X Beo1 Type 851X Beo1 Type 852X Beo4 Type 8531 through 8540 Beo4
Hagen2000
- Joined on 05-08-2007
- Munich
- Posts 267
Hi together, I read this thread with interest and came to the following assumption: Is it possible that the Beo1 is always operating in LINK mode? It might be worth a try to control your BV1 by the Beo4 by preceding each command with LINK, e.g. LINK SAT or LINK RADIO etc. (while the BV1 is configured to be controlled by the Beo1).
- UK
- Posts 970
Thanks but I'm afraid it didn't work. I OPTION1 my BV1 so the Beo1 worked. I added LINK to my Beo4 list then selected LINK+SAT, LINK+RADIO, LINK+etc and nothing happened. Please keep your ideas coming, I feel that the answer is very close.
Page 1 of 1 (14 items)
