Latest post 04-07-2008 1:47 AM by Mr10Percent. 2 replies.
Page 1 of 1 (3 items)
  • 04-06-2008 2:35 AM
    Beogram 8002
    I have just managed to aquire a good exaple of a BG8002.
    Now I know that this deck does not have an internal RIAA amp, so the question is, what do I need to do so I can get this unit to work and play through say a current BC2. What RIAA amp and cables are required etc...
    Any help is apreciated.
    10%
  • 04-06-2008 4:16 AM In reply to
    Re: Beogram 8002
    I would get one of the cheaper Gram Slee RIAAs. You will need a 5pin DIN to phono converter but the BC2 takes phono plugs. Not sure what you do with the earth from  the DIN plug.
  • 04-07-2008 1:47 AM In reply to
    Re: Beogram 8002
    Thanks Peter.
