Latest post 04-09-2008 8:35 PM by monty. 8 replies.
Page 1 of 1 (9 items)
  • 04-05-2008 4:29 PM
    • monty
    • Not Ranked
    • Joined on 04-05-2008
    • Posts 7
    Avant 32 VCR - UK to Canadian/USA spec?
    Hello,
     I just picked up a used Avant to complement my Beosound. My Beosound is North American spec, but the Avant has the UK plug.
    What adapter/voltage converter do I need so I can use the TV safely without blowing up my house? lol. I've attached a photo of the plug in question. Also - how do I connect an external cable box or DVD player? Will an SCART adapter work?
  • 04-05-2008 5:29 PM In reply to
    Re: Avant 32 VCR - UK to Canadian/USA spec?
    That is a UK plug so you have a 230V model. You therefore need a step up transformer capable of increasing the voltage to 230V. It needs to be a very heavy duty one! There has been a thread about this before - it was about a DVD Avant but same basic idea - look here!
  • 04-05-2008 9:25 PM In reply to
    • monty
    • Not Ranked
    • Posts 7
    Great thread! Thanks for the link to that. I will be using an external cable box/DVD Player so I have no problem with decoding.
    However, I'm confused re: the transformer solution though. The poster bought a step up/step down convert for 300 watts and it didn't work, however he then bought a 250w model and it worked properly? Here are the details from my set:
    Beovision 32 VCR
    220-240v ~50/60Hz
    Power Consumption: 110w
    Item# 1835108
    Type 84/02
  • 04-05-2008 11:02 PM In reply to
    • monty
    • Not Ranked
    • Posts 7
    is there a voltage switch on these units? i can't seem to find one and the eBay seller seemed to think there was a switch, then all i would need is an adapter for the plug and i wouldnt have to worry about a step-up transformer.
    seems too easy...
  • 04-06-2008 2:29 AM In reply to
    There is no switch, you will definitely need a transformer.
    Regards Graham
  • 04-06-2008 7:50 AM In reply to
    • monty
    • Not Ranked
    • Posts 7
    Thought so!
     What wattage of step up transformer will ensure the TV works at peak performance? I heard that even though the TV says "110w", I should get something much higher since the power surges when the TV is first turned on.
  • 04-06-2008 8:05 AM In reply to
    The wattage drawn by the AVANT with VCR is actually 185 watts at 240 volts.
    The other member (Link previously provided by Peter) with the same issue purchased a 300 watt transformer because the AVANT does not have a large tolerence on mains voltage and if you purchase a transformer just above the actual current drawn it is likely to saturate and so not provide voltage within the tolerence range. Also remember that you are running at 110 volts from your normal sockets, so the current is higher, but is not double.
    Therefore I suggest you purchase at least a 300 watt transformer.
    Regards Keith....
  • 04-06-2008 8:47 AM In reply to
    • monty
    • Not Ranked
    • Posts 7
    Great. I'll purchase a 300w step-up transformer and let everyone know how it works out.
    Thanks for your help.
  • 04-09-2008 8:35 PM In reply to
    • monty
    • Not Ranked
    • Posts 7
    Just got my step-up transformer and it works like a charm.
    Thanks for everybody's help!
