Latest post 04-07-2008 4:31 PM by Medogsfat. 6 replies.
Page 1 of 1 (7 items)
  • 04-05-2008 10:53 AM
    • runt
    • Not Ranked
    • Joined on 04-02-2008
    • Posts 9
    • Silver Member
    can i link a cd 4500 player
    to my 7007 or could someone give me a list of cd player that i can
  • 04-05-2008 11:04 AM In reply to
    Re: can i link a cd 4500 player
    Duplicate post.
  • 04-05-2008 11:11 AM In reply to
    I connect my CD player to my Beocenter 7000 using a DIN to RCA converter lead that I got from eBay.
    I *think* the Beocenter 7007 has a bigger range of connection options than the 7000. hopefully someone will be along in a bit who can confirm this.
    The Becnter 7000 series have superb amplifiers in them, so it is well worth doing.
    Simon
  • 04-05-2008 1:06 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    You may find you will have to remove the two Datalink pins from the DIN plug on the CD player. These are pins 1 and 7 and should just unscrew.
    CraigSmile
  • 04-05-2008 1:52 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Do as Craig suggests but don't lose the pins as they are very hard to find replacements for then plug directly into the tape 2 input socket.
    Chris.
  • 04-07-2008 4:17 PM In reply to
    • sveifors
    • Top 500 Contributor
    • Joined on 04-16-2007
    • North of Norway
    • Posts 145
    Instead of destroying your pins you can get  from your B&O dealer Part no 7229072  a 7 pin to 5 pin DIN adaptor
    7-pin female/5-pin male. For connection of Bang & Olufsen products with 7-pin DIN sockets to product..with 5 pin
    Sveifors Always look on the B & O side of life
  • 04-07-2008 4:31 PM In reply to
    • Medogsfat
    • Posts 4,045
    You won't actually destroy the pins by removing them as they simply unscrew. They have slots in them for a small flat head screwdriver if you look closely.
    Whenever I've done this I simply tape them to the lead so I don't lose them.
    Chris.
