Latest post 04-09-2008 2:16 PM by camshaft. 26 replies.
Page 1 of 2 (27 items) 1 2 Next >
  • 04-04-2008 2:28 PM
    Penta II problems
    Hi guys...
    Got a troubling set of pentas..
    1st speaker) When connected with 8 pin powerlink...  (AMBER LIGHT)....and will give sound for say 3 seconds ONLY when switching between Auto/L/R on the mode switch...then goes off...then switch again..and it plays for another..3 seconds... NO DISPLAYS
    2nd speaker) red light all the time....no sound no matter what we do.... NO DISPLAYS
     Ideas??
  • 04-04-2008 3:57 PM In reply to
    Re: Penta II problems
    yeahhhhhhh..........
  • 04-04-2008 11:13 PM In reply to
    • camshaft
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Pennsylvania, USA
    • Posts 575
    Hopefully I'll be able to answer questions like this when I actually pick up my pair this coming Friday, as I've never even seen them in person.  But for the 2nd speaker with the continual red light, have you checked the fuse?
    -Austin (resident audiophile skeptic)
  • 04-05-2008 1:40 AM In reply to
    Hey Austin...
    I've downloaded the manuals....but as i'm on the short-bus....where is the fuse on the pentas???
    gracias...
  • 04-05-2008 2:52 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    At the bottom of the tower, accessed from below behind a little cover held by one screw if I rememeber correctly.
  • 04-05-2008 5:20 AM In reply to
    I went through the manual......is there a Penta fuse??? That could be causing these problems???
    Thanks..
  • 04-05-2008 11:06 AM In reply to
    I don't see anything about this in the service manual.....so...
    To remove the thick plastic coating on the lower base of the pentas.....does it just pull off??
  • 04-08-2008 11:56 AM In reply to
    HI guys..
    Got the amps opened up on the Penta II's.....a coil fell out (pic below)...and a dark, burnt spot on the board...(see pic)..
  • 04-08-2008 12:10 PM In reply to
    Here's a close up of the board that on the first Penta II..... Ideas of where to start would be greatly appreciated...
  • 04-08-2008 12:52 PM In reply to
    It's the C4 Capcitor that is bad.....what is that for???
    Thanks !!
  • 04-08-2008 1:08 PM In reply to
    • magnushj
    • Top 500 Contributor
    • Joined on 08-16-2007
    • Trondheim, Norway
    • Posts 139
    • Silver Member
    Don't know what it is for. Try replacing it, and while you're at it find out where the coil is supposed to go and put it back. Wink
    You probably also want to replace all the electrolytic capacitors.
    Beocenter 9500+Beolab Penta mk2+Avant+MX7000+Beosound Ouverture+1xBeolab 6000 :)
  • 04-08-2008 1:21 PM In reply to
    • Dillen
    • Posts 5,008
    Frank,
    Slow down, my friend ...
    Don't haste things. Look in the manual and find info there before assuming (wrong).
    Of course, there is at least one fuse, and the Beolab Penta's have two.
    One fuse is for the controlling electronics, the other is for the amplifiers.
    C4 is clearly bad, not a surprise with that type of capacitor, I'm afraid, but the reason still needs to be investigated.
    According to the schematics C4 is directly in series with a 10 Kohm resistor. This
    tells the experienced technician that there DEFINITELY are other things that need attention.
    The dark spots seens elsewhere on the board only confirms this.
    The lose coil didn't even come from this part of the tower so there will be more to service before powering up again and don't just add mains to this thing. Power it up from a variac, not only for your own safety.
    Don't get me wrong, Frank, but repairs like this are not some you can do "at the kitchen table". They are better left to a qualified technician one who has the proper instruments etc.
    It will probably not be an expensive repair and it's always well worth the money spent to have it done by a pro.
  • 04-08-2008 1:30 PM In reply to
    Hi Martin...your input is much, much appreciated....
    I understand....i've got an electronics guy now working on it.....(this stuff is all foreign to me).... he's experienced with micro soldering, caps, resistors...etc...but not at all with BnO...
    Sorry for my haste....i've just got to translate all this to spanish for them...and it's dicy....
    Yes..he told me tha the coil is from the crossover....
    He has confidence that with direction he can fix what we need...and he's got all the instruments that a standard TV type repair man would .....have...
    Again...the manual is good for me...(but im no electrician..) so i'm not sure even what to translate for him...
    OH.....the RESISTORS are new and replaced...(but you can see that they were burnt before)......is what he's telling me...
    Ideas for other things that need attention....as we begin to try to fix this thing..??
  • 04-08-2008 1:36 PM In reply to
    • Dillen
    • Posts 5,008
    Great !
    I'm afraid, I can't give you more hints without actually measuring about a bit.
    Give the technician a couple of minutes to look at the schematics and understand the circuitry and he will know where to measure and what results to expect.
  • 04-08-2008 2:48 PM In reply to
    Hi Martin,
    Strange...on the PCB 2....ours says 8001086....
    In the book it says it should be...8001165......
    Ideas..
  • 04-08-2008 3:06 PM In reply to
    Frank,
    You should not concern yourself about the different part numbers of the boards.
    As the capacitor C4 pop'ed it is likely that at least one or more of the following components will have failed:-
    TR6 (BC548B) -- D6 could be short circuit -- D5 -- TR5 -- Tests these components
    Also it should be noted that C4 is rated at 25 volts
    Regards Keith....
  • 04-08-2008 3:28 PM In reply to
    Thanks Keith.....(yep..25 volt for the C4..got it...)
    Also....they are going out for these now the BC548B's (x2) per speaker...
    They don't list the D5 and D6 in the manual....can we just take the board to the parts shop?? Or do you have a reference for these...??  Strange, no??
    THanks,
    Keith
  • 04-08-2008 3:31 PM In reply to
    D5 & D6 are both IN4148 diodes
    Just taking the board to a parts shop will not help you.
    Regards Keith....
  • 04-08-2008 3:33 PM In reply to
    Thanks Keith.....he was ready to dis-mount them....he could see the 1N... but with your help....PERFECT !!!!
    Also,....Keith....do you know the Diode codes for the D7 and R22.....??? They are not in the pdf file...
    gracias..
  • 04-08-2008 4:51 PM In reply to
    Hi Keith...
    On PCB 1........in the service manuals...they have no listing for....some resistors that look suspect..  can anyone tell me if these are correct....below...
    R 65, R 66, .....150 k Ohms each yes??
    and R 86..... 390 Ohms.. yes??
  • 04-09-2008 2:29 AM In reply to
    Frank,
    D7 is also an IN4148, this is a high speed switching diode made by Philips
    R22 is a 680 ohm resistor
    Regards Keith....
  • 04-09-2008 2:37 AM In reply to
    Yes, R65 & R66 are 150 K Ohm and are in parallel to give an effective resistance of 75 K Ohm. The reason they have done this is because resistors come in standard values, so the nearest value would be 68K or 82K.
    These two resistors have a low tolerance requirements, so you should get at least 5% version. 5% resistors usually have a "gold" band around the resister if it is not written and "silver" for 10%.
    Yes R86 is 390 Ohms..
    Regards Keith....
  • 04-09-2008 1:14 PM In reply to
    Keith...i really appreciate your help.....!!
     I'll keep you informed on how things come out...
  • 04-09-2008 1:24 PM In reply to
    Also...since...we had 2 of the glued coils come off on the crossover board...
    What glue / resin...do you use to stick it back on??
  • 04-09-2008 1:37 PM In reply to
    • camshaft
    • Pennsylvania, USA
    • Posts 575
    Usually something like two-part epoxy is fine.
