Latest post 05-05-2007 1:33 PM by marcus_m. 3 replies.
Page 1 of 1 (4 items)
  • 05-04-2007 10:19 AM
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Will this setup work?
    I am thinking about using playing my MP3 files (stored on a network nevice) via a MAC and control it easily with the Beo. Right now I use a X-box with XBMC which works nice, but another remote control on the table...
    I got a Beovision 3-32 with DD module, 5 speakers connected to it. Via ML (and a converter, of course) a Beocenter 2500 is connected.
    How can I use the Beoport now? I know, connection to a MAC, USB and sound plug is needed, IR-eye makes sense, too. No problem there. But how about connecting the system to my setup?
    Can I use the Power Link connection of the Beolink Converter (Type 1610/1611) and listen to MP3s via this connection? (is N.Music/N.Radio available, too - I suppose not, since the Beocenter is not capable).
    How do I get the Video signal to the TV then (for showing FrontRow for example)? Just a diret connetion from mac to tv, I suppose.
    Thanks for you help!
    Best regards
    Ralf
    PS: Beovision 3-32 has Masterlink, the Beocenter 2500 hasn't, Beolink Convertes Type 1610 and 1611 available.
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 05-04-2007 11:51 AM In reply to
    Re: Will this setup work?
    Ridax had a solution that allowed you to connect a PC or Mac to these systems. Has he rejoined?
  • 05-04-2007 12:49 PM In reply to
    • BeoIce
    • Top 200 Contributor
    • Joined on 03-27-2007
    • Recklinghausen, Germany
    • Posts 281
    Hi Ralf,
    why don't you keep your X-Box and ask Ulf if he can modify it to be controlled with Beo 4 ?
    Regards
    BeoSound 9000 MK III, BeoLab 6000, BeoLab 11, BeoCenter 2300, BeoSound Century, BeoVision MX4000/MX7000 & BeoCom 4
    Samsung UE40B7090, Samsung HT-WS1G, Technisat HD8-S, Sony PS3, Logitech PS3 IR-BT-Adapter & Lintronic TT455-RT-238
  • 05-05-2007 1:33 PM In reply to
    kallasr:
    You're right. I had a similar setup with Beocenter2300 and all I tried wasn't that convenient it should be... Finally I gave up and upgraded the Audio system. Now everything works like a charm, also in the link rooms :)
    Marcus
