Thanks for the positive feedback, Nick, it means a lot coming from a guy like you !
There is a specific kit for each model. Or at least there will be. The number of different machine versions and also different models of displays are almost endless.
So far, I have kits ready for Beocord 6000,6002,8000,8002,8004,9000 and Beomaster 6000,8000
The rebuild service works on core exchange basis, meaning that I will need to have the defective display(s) sent to me and you will receive a rebuilt display of the same type (or the actual same display rebuilt), together with a handful of components for you to replace to convert the machine for use with the rebuilt displays.
Detailed instructions are included with the kits. Basic soldering skills and tools are required to replace the components and displays.
In the Beomasters 6000 & 8000, the displays will have to be done in pairs because of the way they are electronically controlled.
For the Beocord's, dedicated kits are also available for the VU level meter display.
Missing LED segments seems to be more and more common but since this solution is still fairly new, kits for the Beocenter 5000,7000,7002,7007,7700 are still in the making, some actually soak testing as I write this, hopefully ready soon.
