Latest post 04-04-2008 1:48 AM by kawo. 7 replies.
Page 1 of 1 (8 items)
  • 04-02-2008 12:56 PM
    beolab 5 sub
    Why is it not possible to make  subwoofer changes in a 5.1 set-up for the beolab 5
    I've been told that it only can be done when you connect a beolab 2 subwoofer.
    I think that's very strange.....no adjustments in sound for a sub
  • 04-02-2008 12:59 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: beolab 5 sub
    As far as the BeoSystem/BeoVision setup is concerned, the BeoLab 5s are just another pair of speakers, except they can go much deeper than other speakers. There is no 'subwoofer' when using a pair of BeoLab 5s...
     Weekly top artists:
  • 04-02-2008 1:40 PM In reply to
    • kawo
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 516
    Re: beolab 5 sub
    Alex, I think the question was if it is possible to change the level of the LFE channel even when it is mixed to the front channels in a Lab5 setup. At least from my point of view a possible adjustment would be nice. However, in my setup it works perfectly, which suprises me every time.....
    Karsten
    _________________________________________________________________________
    BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
  • 04-02-2008 1:55 PM In reply to
    • Alex
    • Posts 2,990
    Re: beolab 5 sub
    I don't think there is a way of doing this sadly. The 'bass' control may help things a little though...
     Weekly top artists:
  • 04-02-2008 2:25 PM In reply to
    Re: beolab 5 sub
    The 'bass' control also reduce the bass from the rear speakers.
  • 04-02-2008 2:29 PM In reply to
    • Alex
    • Posts 2,990
    Re: beolab 5 sub
    A little crude, but you could always just set the position switches in the rear speakers to 'free'. This should boost the bass - assuming you haven't done this already...
     Weekly top artists:
  • 04-03-2008 2:17 PM In reply to
    Re: beolab 5 sub
    Alex:
    beolab 6 & 8000 don't have switches Alex
    But that's not the point.
    On every subwoofer you can make LFE adjustments,I think it's a design fault!
  • 04-04-2008 1:48 AM In reply to
    • kawo
    • Posts 516
    Re: beolab 5 sub
    As mentioned before, it would be nice to adjust the LFE level, but did not miss this possibility with my Lab5 so far.
