Latest post 04-04-2008 9:39 AM by joeyboygolf. 12 replies.
Page 1 of 1 (13 items)
  • 04-02-2008 10:45 AM
    Modified Beo4 remote
    Hi guys.
    I desperately need to know if anybody knows how to modifiy a Beo4 remote to make it multi regional.
    Thanks in advance- please help me asap!!
    Thanks alot
    Jamie (",)
  • 04-02-2008 10:51 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Modified Beo4 remote
    When you say multi-regional, do you mean one which sends out the correct messages to make a B&O DVD player multi-region?
     Weekly top artists:
  • 04-02-2008 10:54 AM In reply to
    Yes to make B&O DVD players multi region (incuding BeoCentre 2 DVD player)
    Thank you very much
    Jamie
    • Kokomo
    • Top 100 Contributor
    • Joined on 08-21-2007
    • Spain
    • Posts 618
    jimbo_the_greatest:
    Hi guys.
    Thanks alot
    Jamie (",)
    Do you mean multi-language rather that regional?
  • 04-02-2008 11:07 AM In reply to
    • Alex
    • Posts 2,990
    jimbo_the_greatest:
    Thank you very much
    Jamie
    As far as I am aware, it's one of those things which you need some special kit to do, whether it's a computer loaded with the correct software/hardware or a special chip mounted on the circuit board. I don't really know anything else about them, I'd say it's not for the faint-hearted!
     Weekly top artists:
  • 04-02-2008 11:13 AM In reply to
    Would you happen to know where I would be able to buy the kit or the chip?.... This is much harder than I thought Smile
  • 04-02-2008 11:32 AM In reply to
    • Alex
    • Posts 2,990
    I don't know - sorry. Maybe worth asking your dealer if they can multi-region your DVD player for you though. I'd imagine they will want to come round and do it themselves...
     Weekly top artists:
  • 04-02-2008 12:27 PM In reply to
    Hi:
    Apparently, from what I remember B&O will not do this for you directly. However, they will recommend someone that can do it for you. I think this is a case of altering the Firmware and for this you need a computer loaded with the right software. It will also void your warranty.
    Have you tried it with a Philips remote?  Some of the later PVRs and the DVD2 are Philips devices in nice cases. Again this will almost certainly mess up your warranty.
    Hope this helps
    Graham
  • 04-04-2008 6:43 AM In reply to
    Thanks very much for your help. One last thing, I know this is very far fetched, but would you happen to know or have a have a rough idea how I would be able to get hold of this software where I can buy it or something?
    Jamie
  • 04-04-2008 7:36 AM In reply to
    I would google it - I think you can buy DVD unlocking software which has all the unlock codes via remote on them (well they say all but  I doubt it). I have never used these. I have only unlocked a DVD with a free code before someone realised the commercial potential of bundling all codes together and selling them.
    I would just google using different search terms such as DVD cracks, DVD firmware software, DVD hacks etc. Or ask a friendly TV salesman who does not have an interest in keeping the info from you. I am bored at work so will have a look for you too and see what I can find.
    However, as what you are attempting to do is possibly illegal, or at the very least frowned upon I doubt you will have any comeback if you break your equipment. Or, if you buy something and it does not do the job.
    Hope this helps
    Graham
  • 04-04-2008 7:44 AM In reply to
    Follow this thread and associated link.
    Looks as if it works.
    http://forum.beoworld.org/forums/thread/50914.aspx
  • 04-04-2008 9:03 AM In reply to
    Cool thanks for your help hey. What I'm really trying to do is use my Beo4 remote so that I can multi region other Bang & Olufsen DVD products (but not DVD2).
    Sorry for being such a pain :-)
    Cheers
  • 04-04-2008 9:39 AM In reply to
    You can buy a modified Beo4 which will do this job. Someone in Scandinavia I believe but I can't recall who or where!
    Regards Graham
