What exactly do you want ? Do you want information about the product and how it can be used with B&O Powerlink speakers ?
Or, do you just want to know where buy the unit. If you want to know where to buy one, I suggest you review some of the German/Danish sites.
Regards Keith....
yes, I would like to buy one.
What sites?
The X501 will be quite hard to find,as it is are no longer being produced.
From time to time they are on eBay.Or perhaps ask around on the German forum.
Ignace www.iggyswebsite.com
Muchos Gracias
OK.
How do I connect a Pioneer 50" plasma to a Ouvertyre, Pentalabs, BL6000 or 2500 and a non B&O sub?
Yes, I will be using Lintronic to control everything.
Thanks in advance!
I have a Pioneer 50" plasma, an Ouvertyre, Pentalabs, BL6000 or 2500 and a non B&O sub, how do I connect them together?
If you're in the North West, call in or give me a call.
regards
David
Bang & Olufsen of King Street - Manchester,UK. SKYPE - beokingstreet
ebay item 220220201115. Find it on advanced search by number. It's on the German site from someone I've used before with no problems. 9 days to go and starting at EUR299.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220220201115&ru=http%3A%2F%2Fsearch.ebay.co.uk%3A80%2Fws%2Fsearch%2FSaleSearch%3Fsofocus%3Dbs%26satitle%3D220220201115%26sacat%3D-1%2526catref%253DC5%26dfsp%3D32%26from%3DR7%26nojspr%3Dy%26pfid%3D0%26fsop%3D32%2526fsoo%253D2%26fcl%3D3%26frpp%3D50%26fvi%3D1
Good luck,
Dave.
Am I ready? I was born ready!
OK - hope you get sorted.
Regards
Hi
I have a DeToma X501 for sale, if you are interested.
Best regards,
kspetersen
