1st March February 2012
Latest post 04-02-2008 12:32 AM by Ignace. 9 replies.
04-01-2008 12:38 PM
beoblok
- Joined on 03-19-2008
- Finland
- Posts 80
Beo4+Beocenter 9500+(Beovision Avant)
Hello. I wondered if there is a listing of Beo4 remote functions in combination with a Beocenter 9500 ? I can make the basics work but would, for example, like be able to "eject" the cd from the remote. As the Beo4 offers a lot of compatibility options (as they say) I would love to learn about them... Thanks, beoblok
beoblok
- Finland
- Posts 80
Re: Beo4+Beocenter 9500+(Beovision Avant)
Thanks Graham. Not the answer I hoped for.. But this is how it is then. Any suggestions how to get the most out of the Beo4 in combination with the BC 9500 otherwise? I'm honestly a bit lost while using the remote. Not with the Beovision but though with the BC. Thanks, beoblok
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
beoblok: like be able to "eject" the cd from the remote. Thanks, beoblok
Don't listen to Graham, Beoblok, It can be done!!
Jandyt
- Posts 13,004
Yes, what a waste of six minutes that was! I could have been doing something constructive......... like watching 20% of tonight's episode of 'Eastenders'
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
Surely you are not a fan of 'Eastenders' ? When Eastenders' starts I leave my wife to it and come up to the PC and login to Beoworld....
Ignace
- Joined on 03-30-2007
- Moderator - NL
- Posts 2,749
beoblok:Thanks Graham. Not the answer I hoped for.. But this is how it is then. Any suggestions how to get the most out of the Beo4 in combination with the BC 9500 otherwise? I'm honestly a bit lost while using the remote. Not with the Beovision but though with the BC. Thanks, beoblok
Hi beoblok, I've answered your topic on the Dutch forum.
Page 1 of 1 (10 items)
