Latest post 03-31-2008 2:28 PM by Jandyt. 5 replies.
Page 1 of 1 (6 items)
  • 03-31-2008 7:18 AM
    • Ian
    • Top 500 Contributor
    • Joined on 04-16-2007
    • UK
    • Posts 132
    TV Button on BL2000
    The TV button on the BL2000 - What happens on a TV with a DVB-T module? Because the TV button on a Beo4 goes to a analogue signal and the DTV goes to digital. Does theTV button on the BL2000 work in the same way? If so, how can you get TV sound from a digital channel?
    Ian
  • 03-31-2008 8:00 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    Re: TV Button on BL2000
    The DVB-T/S module is activated by pressing DTV - so, on a BeoLab 2000 you will have to use a Beo4's DTV-button to get the sound from your DVB-T/S module.
    Roger
  • 03-31-2008 8:10 AM In reply to
    • Ian
    • UK
    • Posts 132
    Thanks Roger. So if I used the TV button it wouldn't work and I would just get silence (unless I had a analogue signal to the TV analogue tuner?
     Ian
  • 03-31-2008 8:16 AM In reply to
    • Roger
    • Norway
    • Posts 870
    Yes, that is correct. The TV button is becoming obsolete as analogue transmissions are coming to an end (we have no analoge TV in my neck of the woods as pr March 1st) - perhaps B&O should re-map the TV button as the new SAT/DTV button?
    Roger
  • 03-31-2008 9:47 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    Roger:
    YES Yes -  thumbs up
    They did change it from [ATAPE] to [TV] some years ago.. Now it´s time for a new change. If not [DTV] so why not [N.MUSIC] or [N.RADIO]?
  • 03-31-2008 2:28 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Sad about the TV button. It also makes the A9 keyring only 66.666% useful!
    Beo4 needs changing to this (robbed off Ignace, sure he won't mind)
    Poor me, never win owt!
