Latest post 03-29-2008 1:40 PM by banger2004. 0 replies.
Page 1 of 1 (1 items)
  • 03-29-2008 1:40 PM
    • banger2004
    • Not Ranked
    • Joined on 09-13-2007
    • Clanfield Hampshire
    • Posts 14
    Avant Picture Format problems
    I have a 5 year old Beovision Avant 28" RF DVD, nad am loahted to get rid of it until the LCD technology can provide a picture of comparable quality.
    However, it has recently started playing up with regard to the picture formatting.
    If I watch Sat, the picture format usually goes to option 2 and then I have to manually overide it to option 3. When watching DVD, the screen is usually not filled left to right - I know that you sometimes get the letterbox effect but this is not the problem. Ocasionally, the Avant will turn on all five speakers then revert to 3 and so on.
     Is there a specific module within the Avant that looks after picture formatting and if so can it be chanegd easily?
    Paul
    Filed under:
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
