Latest post 04-06-2008 5:07 AM by Beolab1. 32 replies.
Page 2 of 2 (33 items) < Previous 1 2
  • 03-30-2008 5:34 AM In reply to
    • Soren
    • Not Ranked
    • Joined on 05-04-2007
    • Kolding Denmark
    • Posts 56
    Re: Connection challenge Beosystem 7000!!!
    Like you can se here on this copypast from http://www.hardwarebook.info/DIN_Audio
    The output from the taperecorder pin 3 & 5 goes to the input pin 3 & 5 on the amplifier.
    and when recording output from the amplifier pin 1 & 4 goes to the input pin 1 & 4 on the taperecorder.
    But you have 2 amplifiers that means that the output from the amplifier (BM7000) pin 1 & 4, goes to the input pin 3 & 5 on theother amplifier (BS9000).
    Søren
    DIN Audio
    From HwB
    [edit] Pinout
    5 PIN DIN 180° (DIN41524) FEMALE at the peripheral.
    5 PIN DIN 180° (DIN41524) MALE at the cable.
    Peripheral Connected In L In R Out L Out R Ground
    Amplifier Pickup, tuner 3 5 2
    Amplifier Taperecorder 3 5 1 4 2
    Tuner Amplifier 3 5 2
    Tuner Taperecorder 1 4 2
    Recordplayer Amplifier 3 5 2
    Taperecorder Amplifier 1 4 3 5 2
    Taperecorder Receiver 1 4 3 5 2
    Taperecorder Microphone 1 4 2
  • 03-30-2008 5:59 AM In reply to
    • Beolab1
    • Top 500 Contributor
    • Joined on 08-04-2007
    • Hong Kong
    • Posts 232
    • Gold Member
    Thanks a lot guys! I'm starting soledering right away. I'll keep you posted!
  • 03-30-2008 8:35 AM In reply to
    • Beolab1
    • Hong Kong
    • Posts 232
    • Gold Member
    Gentleman, it is working!!!!! There is only one small detail. The right channel is coming through all four speakers, so I'll have to check the soledering again. But never mind, we have almost broken the challenge!!!!! I can now listen to the beautiful sound of the Beogram CD 7000, the Beogram 7000 and the Beocord 7000 through my system. THANK YOU all so much for all your help, you guys have all just been great!!!!! I'll let you know when I have tackeled the right channel only issue. It has been a privilege blogging with you!!!!!
  • 03-30-2008 6:32 PM In reply to
    • Beolab1
    • Hong Kong
    • Posts 232
    • Gold Member
    The job is finished, evenrything works beautifully. Thanks again for all the help!!!!!
  • 03-30-2008 7:09 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Beolab1:
    Glad to hear you got it all working in the end.Wink
    CraigSmile
  • 03-31-2008 4:57 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Congratulations and have fun with your "new" system. As I mentioned before, if you want to control both systems with one remote, get your BS 7000 into A.OPT. 0 and connect an MCL 2A (in L.OPT. 4). Now you can control your BS 9000 with RADIO, CD, A.AUX and the BS 7000 with LINK-CD/RADIO/PHONO...
    Stefan
  • 04-01-2008 9:59 AM In reply to
    • Beolab1
    • Hong Kong
    • Posts 232
    • Gold Member
    Thanks Stefan, i'll look in to that!
  • 04-06-2008 5:07 AM In reply to
    • Beolab1
    • Hong Kong
    • Posts 232
    • Gold Member
    I,ve been enjoying my Beosystem 7000 the last week and since everybody was so helpful. I've joined Beoworld as member!
