Latest post 05-04-2007 4:31 PM by sajpratty. 5 replies.
Page 1 of 1 (6 items)
  • 05-03-2007 5:26 PM
    Idea [I] Beomaster 1000 Lamps
    My Dad's Beomaster 1000 needs a full set of lamps.
    The tuning scale lamps are not a problem - Maplins sell BU19V R10 MES 6.5V 300mA which is as near as makes no difference. Sorted.
    The stereo indicator is stumping me though. It's a 19Volt 0.097Amp, PHILIPS 8097D/71 IMPX (part number 8230004), should be common as muck because they were used in all sorts of old radios, but I can't find one anywhere. Nearest matches I found were also from Maplins - either a BU20W R10 MES 12V 100mA or a BU21X R10 MES 12V 183mA. (They do 24V flavour as well, but I thoughtthey might be a bit dim - 50mA and 125mA rated.)
    Ideally I'd like the proper replacement, but I gather they are unobtainable. Failing that then, which of the contenders I've found would be the best option? Or should I get one of each and try them and see?
    Many thanks in advance,
    Steve
  • 05-03-2007 6:22 PM In reply to
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    Re: Beomaster 1000 Lamps
    I  would go for the 24v as the 12v will not last too long with something approaching 19v passing through them!
    Brian
  • 05-03-2007 6:49 PM In reply to
    Ask Dillen! He has more Beomaster 1000s than anyone else I know!
  • 05-03-2007 7:32 PM In reply to
    Thank you Brian and Peter.
    Yes, I did wonder about the wisdom of putting a 12V bulb in the way of 19V... Then I started using the v=ir formula and calculating the resistance of the bulb and ended up wondering if a low wattage 12V item might not be a closer match... Then I started to get confused Confused
    No doubt Dillen knows for sure. It's an odd little bulb though - looks like its covered in plastic.
    Steve
  • 05-04-2007 2:44 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    The Beomaster 1000 stereo indicator lamp is shielded in a pertinax tube that will (or at least should) just slide off.
    Underneath you'll find a normal E10 bulb envelope but the rating of 18/19V is a bit odd.
    I have correct lamps in stock.
  • 05-04-2007 4:31 PM In reply to
    Hi Martin,
    Many thanks - I'll be in touch to order a new bulb.
    I had one out of one of my BM1000's to check it - 19V is what it is marked as. The glass envelope seems to have a plastic nobbly coating on it, I'm guessing it would act as some sort of diffuser, not that it would be needed here. The sleeve came off nicely - no sticking! Hopefully Dad's will be as easy to swap.
    Steve
