On the back of the unit there is a 7-pin DIN connector Tape2/Phono. From the beotech articles it appears that the pinout is such that there are not two separate channels, that you can have either a second B&O datalink device or a phono, but not both. Otherwise the output from the two devices are connected to the same input pins. Is this a correct understanding? Or was the idea that the datalink would control it such that only one device would be "talking" at a time? At the moment I have my computer sound output connected to it and it plays the sound in both phono and tape2 modes.
