Latest post 06-11-2007 5:27 PM by joostdeclercq. 12 replies.
Page 1 of 1 (13 items)
  • 05-03-2007 7:37 AM
    • EOB
    • Top 500 Contributor
    • Joined on 04-18-2007
    • Posts 188
    VX 5500 eject problem
    I would like some advice concerning a VX 5500 which isnt ejecting the tape,......
    Regards EOB
    PS do all VX have red led lights to read out or are there some with green ?
  • 05-03-2007 1:12 PM In reply to
    Re: VX 5500 eject problem
    I think they are all red - I am sure all mine are! On the eject side, it is probably the tape jamming . Does it play? I usually manage by pushing it a bit further in rather than trying to pull it out. If necessary, take the top off.
  • 05-03-2007 3:59 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    There's a belt which drives the eject mechanism under the bottom plate, this may well have perished - I had this problem and that was the cause. If memory serves me it is the only one in there so you canoot miss where it should go.
    Chris.
  • 05-03-2007 5:53 PM In reply to
    • EOB
    • Posts 188
    i took the bottom off and the belt that is running there is ok. out of curiousity I have put the net on and tied to eject it did it but when pushing it bak it didnt take it in every time. It ejected it several times though. Thinking of looking on the other side I turned it and when trieing again ejecting it jammed again.
    would it matter to get the top off ,.....hmm how did it go off ......if you hae some more ideas feel welcome. btw i chiped of a small part on the bottom that doesnt seem to do anyharm though..........
  • 05-03-2007 11:41 PM In reply to
    • cozza
    • New Zealand
    • Posts 119
    Could be the loading basket gear assembly has cracked. It is not an uncommon failure on the VX  VCRs. Cracks in the white plastic end pieces cause the cassette to not load or unload straight, and it jams. Part number is 2700011 , description is gearwheel VX3000 / VX5000.
     The cracked end gears can be easily seen with the loading basket removed.
    Ideally you should manually eject the tape by pressing eject and lifting both sides of the cassette evenly. Exchange of the gear is done with the deck in the unloaded position so as to not upset the mechanical timing.
     Due to the possibility of mechanical misalignment, this is a job best left to a technician.
  • 05-04-2007 1:45 AM In reply to
    cozza:
    Totally true! If the gear is ok, another very common fault are the capacitors on the main motor, they get ruined due to the excessive heat.
  • 05-04-2007 12:01 PM In reply to
    • EOB
    • Posts 188
    if it were the capacitators wouldnt it ,...not at all eject.....It now does it very rarely but sometimes it does. last time was when i tried to press the tape with my fingers while ejecting ,.....but its not in a way that I can repeat it ;(
  • 05-04-2007 1:47 PM In reply to
    If all other functions like fast winding and playing are ok, it is a problem of the gear. If the vcr behaves strange with playing and winding, this is the start of end (of the capacitors).
    Good luck
    Marcus
  • 05-04-2007 2:26 PM In reply to
    • Medogsfat
    • Posts 4,045
    Where are you based EOB?
  • 05-05-2007 5:45 AM In reply to
    • EOB
    • Posts 188
    Amsterdam
  • 05-05-2007 8:15 AM In reply to
    • Medogsfat
    • Posts 4,045
    That's a shame, if you were in the UK I may have been able to help you.
    Chris.
  • 05-06-2007 4:26 PM In reply to
    • EOB
    • Posts 188
    thx for the offer Chris.
    btw the play, rewind,forwrd etc,....are in good order so from whar i read it probably must be the train.
  • 06-11-2007 5:27 PM In reply to
    Hello,
    I have the same problem.  Could you be more specific in where to find these capacitors, because the inside of a VX is a mess and there's no Service Manual here on Beoworld.
    Kind regards
    Joost Declercq
    Gent (B)
