Since my tv LS5000 has only one SCART socket, I have always had this connected to my cable tv box.
VHS machines are so dirt cheap, even B&O ones, I thiguh I'd indulge all of £13 in one on EBAY.
Problem although the cable box does have 2 SCART sockets, one of which is marked VCR, it turns out that I can't use it and the video relies on being connected to the tv to recieve control signals from the remote control.
Easy, just get a AVX1 B&O SCART expander box, so I did.
Now I have some small measure of control over the VHS, however, I have connected it up as per the manuals downloaded from here, but it is not right at all.
I cannot record from the Cable box and replay on the tv.
I wonder if it is something to do with configuration, however the information is not even slightly clear.
I have a Beo4 remote, and a Beolink 1000, and I have tried some of the configurations, but nothing works, or at least when I try to change something, everything stubbornly remains the same.
The Beo4 manual is about as useful as a zip in a dishcloth, it tells me I can add things, but then it doesn't say what the buttons do when you switch over to the newly added item, you'd think they would have some sort of heirarchical menu diagram, but no, its about as obvious and intuitive as Sanskrit to a parrot.
