Latest post 03-22-2008 6:21 AM by karcenty. 18 replies.
Page 1 of 1 (19 items)
  • 03-21-2008 6:30 AM
    Beosystem 3 link problem
    Hi.
    I have a Beovision 4 (Beosystem 3) as a master, connected with at Set Top Box and a V8000.
    I am trying to use the STB and video from my link room, where I have a mx4000 connected with a Beolink Video mk II 1615, but I only get “snow” on the mx4000 screen when I press vtape or sat. I have just installed a RF Link amplifier, but that made no difference!
    My settings:
    Beosystem 3 and mx4000 is connected with master link cable and aerial cable from the RF Link Amplifier.
    Beosystem 3 = option 1 (link frq = 599), RF amplifier = off. MX4000 = option 6 (channel 60-64 = frq. 599) My link setup worked perfectly before, with a Beocenter 1 instead of the Beovision 4, any ideas how to get this setup to work ?
    Kind regards Karcenty
  • 03-21-2008 7:13 AM In reply to
    Re: Beosystem 3 link problem
    karcenty:
    Hi.
    My settings:
    Beosystem 3 must be in option 2. Try that
  • 03-21-2008 7:36 AM In reply to
    I've tryed that as well, but option 2 make no difference.
  • 03-21-2008 7:57 AM In reply to
    Check the connections menu on the MX4000. They should be set to none.
    /Frank
  • 03-21-2008 7:59 AM In reply to
    Thank you, but they allready are.
    Karcebty
  • 03-21-2008 8:06 AM In reply to
    check the connection with the amplifier
    in/out etc
    AND you must have BS3 in opt 2
  • 03-21-2008 8:08 AM In reply to
    Then I would check the ML-cable and the junction box if you got any.
    /Frank
  • 03-21-2008 9:12 AM In reply to
    I checked and double checked every cable, I even made a new ML cable, but it make no difference. Maybe it is a hardware error.
    Karcenty.
  • 03-21-2008 10:50 AM In reply to
    What if you bypass the RF amplifier and press v.tape in the link room. Does the Video start?
    /Frank
  • 03-21-2008 11:02 AM In reply to
    frankmj:
    /Frank
    You must use RF amp. It´s only picture that goes there. All commands goes through ML
  • 03-21-2008 11:08 AM In reply to
    ....mr anders(son):
    frankmj:
    /Frank
    I know, it was just to test the ML-connection, if that works, he has to look at the amp. and the connections to RF.
    /Frank
  • 03-21-2008 11:34 AM In reply to
    It makes no difference. There is no connection between mx4000 and the BS3. If I hold down the red stop button in one room for 3-5 sec. it is only the TV in that room that turns off, normally both TV would turn off.
    It also makes no difference if I disconnect the Beolink Video, only reaction is "snow" on the screen.
    Well I think that I will get a B&o technician to take a look at the problem.
    Thanks very much for your good suggestions.
    Karcenty
  • 03-21-2008 11:40 AM In reply to
    I had a similar problem with an beolink 1611. Solution was to first plug the mx to the mains , wait a few secondsand than the beolink to the mains.
  • 03-21-2008 12:38 PM In reply to
    Have also been tried with no luck.
    Karcenty
  • 03-21-2008 12:55 PM In reply to
    • Marder
    • Not Ranked
    • Joined on 04-18-2007
    • Luxembourg
    • Posts 5
    • Silver Member
    Have you checked the LINK frequens on the BeoSystem 3 should be 599?
    /Mads
  • 03-21-2008 1:16 PM In reply to
    Yes, and I have tried different freq. as well.
    Karcenty
  • 03-21-2008 1:19 PM In reply to
    • kawo
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 516
    I am not sure with the MX, but when I got my used BV1 with ML socket and the Beolink did not work I realized that the BV1 just comes with the ML socket but not with the modul. AfterI got a modul from my dealer and pluged it in it worked....
    Karsten
    _________________________________________________________________________
    BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
  • 03-22-2008 6:02 AM In reply to
    Have you tried to connect a beomaster (sound) to the masterlink plug in the linkroom?
    this way you can test the masterlink connection. choose cd in the livingroom and see if the cdplayer is reacting
  • 03-22-2008 6:21 AM In reply to
    That is a very expensive test ;-) I don't have any beosound system.
    Karcenty
