Latest post 03-20-2008 8:07 AM by damatt. 6 replies.
Page 1 of 1 (7 items)
  • 03-20-2008 4:32 AM
    Beolink Converter 1611 Question
    The Beolink Converter Type 1611 has
    A) in one end a Masterlink socket
    B) in the other a datalink socket (7 pin) and a powerlink socket (8 pin)
    Does anybody know what the Powerlink socket is for ?????
    Many Thanks
  • 03-20-2008 4:51 AM In reply to
    Re: Beolink Converter 1611 Question
    Hmmn ???
    It is a bit strange!
    The Powerlink on the Converter is a input to be connected to Powerlink (out) from an audio system (in Option 0) ?
    Wonder what it is doing ???
    Anybody with a diagram ?
  • 03-20-2008 5:00 AM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    A Powerlink-cable is used when there are no speakers connected the the Audiomaster.
  • 03-20-2008 5:01 AM In reply to
    The Pwerlink socket on the converter is an input and is ONLY used/necessary if no speakers are to be connected to the audio system.
    So, in such a situation the Powerlink on the audio system is connected to the Powerlink socket on the converter
    Regards Keith....
  • 03-20-2008 5:20 AM In reply to
    The question remains about the function of the powerlink input (converter)
    As the audio master is in option 0 - then it will not put any sound on the powerlink ????
  • 03-20-2008 5:39 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Option 0 means that the component will not respond to infrared commands,
    doesn't mean audio is cut out.
  • 03-20-2008 8:07 AM In reply to
    It's for the control of the volume if your Beomaster is in option 0 and the video in option 2.
    Pin 4 (speaker on) and pin 7 (datalink) of the Powerlink are used.
    It will switch on the speakers when you switch on your Beomaster with a button on the Beomaster and not with the remote.
    And you will be able to control the volume and mute the speakers if your beomaster has a volume control and/or a mute button
