Latest post 03-19-2008 12:48 PM by Craig. 7 replies.
Page 1 of 1 (8 items)
  • 03-18-2008 5:24 AM
    • becho4
    • Not Ranked
    • Joined on 03-18-2008
    • Posts 5
    Beolab 2500 adjust
    I have a couple of Beolab 2500 and they sound different. One of them has more bass and more treble.
    I had to open one of them to solve a problem and saw there are a couple of adjustable resistors that modify the bass and treble.
    Anyone knows the procedure to adjust them to get from both speakers around the same sound.
    Thanks in advance.
  • 03-18-2008 5:58 AM In reply to
    Re: Beolab 2500 adjust
    It requires the use of audio signal generator and DVM. Unless you have these together with access to the service manual the adjustments are best left to a service tech. Should not take more than 1 hour and you will need to take both speakers.
    Regards Graham
  • 03-18-2008 11:42 AM In reply to
    • becho4
    • Not Ranked
    • Posts 5
    Hi Graham,
    I have a DVM and a tone generator software for PC. I don't have the service manual but someone sells at ebay a CD with plenty of them, so I will buy it to try.
    Regards
    Alfonso
  • 03-18-2008 3:02 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    becho4:
    Regards
    Alfonso
    If it is the usual 128 manuals on a CD ROM then don't bother. It is not on there, it is mostly the older stuff.
    CraigSmile
  • 03-18-2008 3:28 PM In reply to
    • becho4
    • Not Ranked
    • Posts 5
    That is the item I was talking about:
    http://cgi.ebay.es/ws/eBayISAPI.dll?ViewItem&ih=008&viewitem=&item=180223805731&rd=1
    Do you think it's worth 32 USD?
    Is there a way to get access to the service manual of the beolab 2500?
    Alfonso
  • 03-18-2008 3:49 PM In reply to
    • Craig
    • Posts 4,855
    In that case I would buy it. What I was refering to was a different CD ROM.
    CraigSmile
  • 03-19-2008 5:09 AM In reply to
    • becho4
    • Not Ranked
    • Posts 5
    Thanks for the advice Craig.
    I have just bought it. If the process is explained in that CD I will post it.
    Alfonso
  • 03-19-2008 12:48 PM In reply to
    • Craig
    • Posts 4,855
    If you could send a copy to Peter he can put it in the Manuals section of the site.
    CraigSmile
