Latest post 04-05-2008 11:48 AM by j0hnbarker. 11 replies.
Page 1 of 1 (12 items)
  • 03-17-2008 12:02 PM
    beomaster 3000 1987
    When my system has been switched on for more than 15 minutes, whatever it is doing, i.e. playing a CD, the system reverts to program 3 radio setting. If I switch it off it switches itself back on to progam 3 again. The only thing I can do is to remove the plug. My local dealer says they haven't got parts and it is not worth lookig at. Can anybody help please?
  • 03-17-2008 4:32 PM In reply to
    Re: beomaster 3000 1987
    Edwardo:
    Edwardo - where are you located? I don't know what's wrong with your Beomaster, but there are UK based members here who would be able to service your unit for you if that is what it requires. Unfortunately many of the dealers nowadays are either unable or unwilling (or both) to repair many of the older systems. It's such a shame as virtually everything can be repaired. Let us know where you are and someone may be able to suggest someone to help.
  • 03-17-2008 6:27 PM In reply to
    I am located near solihull in West Midlands
  • 03-19-2008 5:47 AM In reply to
    Not in your direct vicinity, but I can recommend Tim Jarman highly. He is in Farnborough, and can be contacted through www.beocentral.com
  • 03-19-2008 6:33 AM In reply to
    Might be too obvious, but still. Is it possible it's programmed to play that radio program at a certain time of day or something like that?
  • 03-19-2008 11:41 AM In reply to
    Many thanks for your help.
    Looks like I shall have to take it all off the wall and maybe take a trip. I was hoping that if someone could see the problem in situe they might have a better idea of what to do.
    I will try the guy you suggested.
  • 03-19-2008 11:46 AM In reply to
    Thanks for your thoughts but as far as I know it can't be programmed and it's never happened before inthe 20 years I've owned it. I would call it a day but it's like a piece of furniture all screwed to the wall and I am loath to give up on it.
    Thanks anyway
  • 03-19-2008 12:36 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Edwardo, the B&O dedaler in Solihull are very good at getting older equipment repaired. They don't do it on site, they send it away somewhere. Might be worth popping in a seeing them as they are local to you.
    CraigSmile
  • 03-22-2008 11:48 AM In reply to
    Hi Craig,
    Thanks for comments. I tried them first but when I gave them the serial nos etc they said that they couldn't get the bits and  there was no real point in their engineer  coming out to look at it.
    Ed
  • 03-22-2008 1:26 PM In reply to
    Edwardo:
    Hi Craig,
    Ed
    I'd try Tim Jarman if I were you Ed. I'm sure he'll be able to fix it.
    John
  • 04-05-2008 9:39 AM In reply to
    Thanks for advice but the problem has ben solved by Solderon29 who lives quite close and has done a great job for me
    Ed
  • 04-05-2008 11:48 AM In reply to
    Edwardo:
    Ed
    A result is a result, whoever fixed it for you. Glad you got it sorted :)
