Latest post 03-17-2008 7:16 AM by Kokane81. 3 replies.
Page 1 of 1 (4 items)
  • 03-16-2008 6:29 PM
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    hi all
    can anging one help me please
    my  friends child hit my tv on the aluminium with a spoon it has caused a small scratch how can i pepair this ??????
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 03-17-2008 1:45 AM In reply to
    • Dude1
    • Top 500 Contributor
    • Joined on 09-18-2007
    • London
    • Posts 189
    Re: bv7
    Is this natural (silver ) aluminium?  and where on the TV?  The grilles on the speakers can be replaced, this can be difficult as they slide off, but are a tight fit.  Your local Bang dealer can sell you a new one.  If its the TV frame and its a natural colour you can try to polish the scratch out.  This can be done with a fine metal polish - such as mothers or Autosol. Dont use a crap polish on it.  You will then need to use something like IPA to get the oil from the ploish off the aluminium.  Do this with care.  If the frame is a colour, you will need to replace the frame. Talk to your Bang dealer.
    Lastly, did the child escape alive? Devil
  • 03-17-2008 4:06 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: bv7
    yes they did survive lol
    this is in the bottom left corner of the tv frame and its original silver so can this be polished out it looks liek a chunk of the paint has come off ???
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 03-17-2008 7:16 AM In reply to
    Re: bv7
    Yeah frame can be replaced easily, just need to take the back off, dvd cover off then the front glass and finally undo a few screws and wham bam its off!!
