Latest post 03-17-2008 5:08 AM by rfc1. 18 replies.
Page 1 of 1 (19 items)
  • 03-15-2008 3:13 PM
    • rfc1
    • Top 500 Contributor
    • Joined on 02-06-2008
    • Posts 166
    • Gold Member
    Operation of Beomaster 6500
    I recently got a Beomaster 6500, but i am not sure if i will need a MCP to operate it correctly, as i cannot get much sense out of it by jabbing randomly at the front panel!!!
    In the manuals section there is only a set up manual for this model, or a user guide for the beosystem 6500 but incorporating a beolink 7000 remote which i obviously dont have.
    Any help on this one gents?
    cheers Sandy
  • 03-15-2008 3:22 PM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Re: Operation of Beomaster 6500
    Hi Sandy,
    You´ll need a Beolink remote to get some functions working.
    If no MCP 6500 or Beolink 7000, do you have a Beolink 1000 or 5000 ?
    (or another B&O remote)
  • 03-15-2008 3:29 PM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    I have a Beo4 remote, but dont think this will work?
  • 03-15-2008 3:40 PM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Should work fine for the basic functions.
    If you press RADIO on Beo4, does the Beomaster switch on ?
  • 03-15-2008 3:43 PM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    Hmmm, i will need to get back to you later on as my beosound 9000 is too close to the beomaster just now and it is being turned on with the beo4 !!!  I will move the 6500 to another room and then try it.
    sandy
  • 03-15-2008 3:46 PM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    If you use a Beosound 9000, my guess is that you will have
    to set the Beo4 to work with the Beomaster 6500.
    (Beo4 has settings for Beosound 9000 and other audio-systems )
  • 03-15-2008 3:53 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Beo 4 should work fine with it without doing anything to the settings.
    Chris.
  • 03-15-2008 4:13 PM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    OK chaps, will try later when kiddies are in bed,
    let you know how it goes.
    sandy
  • 03-15-2008 5:19 PM In reply to
    Beo4 controls ALL functions EXCEPT programming.
  • 03-15-2008 5:43 PM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    Simeon:
    Yes i have found this out now, it does indeed do all functions except programming the radio stations/frequencys.
    Is there any way to tune the radio stations without a MCP.?
    sandy
  • 03-15-2008 6:05 PM In reply to
    • Alex
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Un-plug the BeoSound 9000 or make sure that whatever happens, ONLY the BeoMaster 6500 is in range of the Beo4 remote (or else you are in danger of messing up settings on your BeoSound 9000 etc...).
    Push Standby + List at the same time on the Beo4.
    Using the up + down arrows, cycle until you reach A.Opt.
    Press Go.
    Press 2 (assuming the amplifier isn't set up in any special configuration etc...).
    The light on the amplifier should flash and the screen should display similar to º2.
    The amplifier *should* now respond to remote control signals (assuming my theory is correct - that it was in the wrong 'Option Format'.
     Weekly top artists:
  • 03-15-2008 6:23 PM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    Alex, went into "options" then GO then got to "A.opt" pressed go and then "2",  beomaster did indeed display  " *2 " which disappeared after a second or so,  now what should i try and press to search for radio frequencies?
    cheers sandy
  • 03-15-2008 6:39 PM In reply to
    • Alex
    • Posts 2,990
    The 'º2' display means the Beomaster 6500 will react to ANY B&O commands it receives, not just a select few (namely those which relate directly to sound, such as CD or RADIO instead of TV and DVD)
    I'd recommend you look for a BeoLink 1000 - the newer the better. The Beo4 is designed to work with B&O's latest products, and while their older kit is not 'incompatible' with the Beo4, you do have to work around things to get it to work all the time. A BeoLink 1000 however, is from the same era as your BeoMaster 6500 and will work much more smoothly (and it's a great remote too, I use one with my 6500).
     Weekly top artists:
  • 03-15-2008 6:48 PM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    yes but will a beolink 1000 command the beomaster to self seek radio stations or indeed allow me to manually tune the unit?
    sandy
  • 03-16-2008 4:07 AM In reply to
    • Christian
    • Top 100 Contributor
    • Copenhagen, Denmark
    • Posts 626
    To tune in a radio station with BL1000 you must press [GOTO] [X] [X] [X] [X] [STORE] [Y ] [STORE], where xxx.x is the station frequency, and y is the is the station under which you want to store the frequency.
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 03-16-2008 4:32 AM In reply to
    • Alex
    • Posts 2,990
    rfc1:
    sandy
    Yes, it will. As far as 'self seek', I'm not sure if this can be done. I can't receive any radio where I live so I don't actually understand how the Beomaster 6500's radio works as well as others.
     Weekly top artists:
  • 03-16-2008 6:25 AM In reply to
    rfc1:
    Simeon:
    sandy
    Yes there is a way of tunning radio stations but its tricky. There is "Tune" option in the list which is designed to tune TVs. But you have to full the system to use it. The "Tune" option is obtained through the "V-Setup" option that you must add to the list.
    Press Radio.
    Now obstruct the beo4 infrared emmiter while pressing "AV TV" on the beo4. You need to obstruct the infrared so that the the Bs6500 will remain on radio mode. You can also achieve this by going to another room and out of range of the bs6500 to press "AV TV" and comming back to range of the BS6500. The reason of this is just to get the v-setup option on the Beo4 while the Bs6500 is on radio mode.
    Select "v-setup" and press "Tune" to tune radio stations. After tunning you can store with "Store" option of the Beo4.
    It sound tricky but once you have done that once it becomes easy.
  • 03-16-2008 8:57 AM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    Thanks Simeon, This does in fact tune the beomaster ,thank you .
    One other question, how to change from FM to AM (mediaum wave radio).
    cheers sandy
  • 03-17-2008 5:08 AM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    cheers sandy
