Latest post 01-20-2011 1:03 AM by stefan. 8 replies.
Page 1 of 1 (9 items)
  • 03-12-2008 2:50 AM
    Beocenter 9000/ 9500 / 8500 wall mount
    In the upcoming few days, i'm having the horizontal mounts made for the CX100's for the wall AND the welder is making a wall mount to hold the BC 9500 to the wall at a 25 degree down angle... I'm having him make drawings with all measurements in metric and i'll post the pics of the diagrams for the site.
    You should be able to have a welder make the mounts off the plans very inexpensively...
  • 03-12-2008 3:38 AM In reply to
    Re: Beocenter 9000/ 9500 / 8500 wall mount
    I presume you have tipped it up and tried the Cd player , 25 deg. must be getting near the limit as the more you incline it the more the Cd carriage gets out of line . I made my Dvd1 stand vertically on it's end but had to put supports inside to get the internal player unit back where it should be because if the sag .
  • 03-12-2008 3:41 AM In reply to
    Hi a2bur.... no, actually I was just looking at the wall mounts available via a vendor and it appears to have about a 25 degree tip...
    If anyone knows for sure what kind (how much) tilt i can do on a BC 9500....that' d be great...
    Thanks,...
  • 03-12-2008 7:16 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    A Danish chap used to make brackets for these beocenters - I had one - and the degree of tilt was 35. My beocenter 8500 played without any problems at all. It also discouraged my cats from walking on it and turning it on at any ungodly hour.Wink
    Chris.
  • 03-21-2008 6:30 AM In reply to
    hi - i read with interest that you're having a wall mount made for your 9500 - have you completed the project?
    i'd be interested if you have any plans/drawings for the bracket(s) that you could email
    cheers - steve
  • 03-21-2008 10:04 AM In reply to
    Hi..... we were working on other things...but intend to have the welder on this....in the coming week....i'll take detailed measurments and pics and post them...thanks..
  • 03-21-2008 4:29 PM In reply to
    I made a wood shelf, but it is horizontal. The supports are wood, painted black.
    BC9300
    BC9300
    BC9300
    Steve
  • 01-19-2011 6:37 PM In reply to
    • Tom Morgan
    • Not Ranked
    • Joined on 10-13-2007
    • Rochester Hills, MI
    • Posts 46
    Hi Chris, long time.  Happy new year and i hope you are doing well.
    I too have one of those 35 degree angle BC9500 wall brackets.  I still use it and it looks great.  I now have a friend of mine who is looking into getting one.  My problem is I can't remember where I got it, but I know it was from some Danish guy.  I think I purchased it off of ebay.  I remember it being aboyt $85.  At the time, I tought it was a very expensive price.  But now that I have had it for so long, I am glad I purchased it.  You wouldn't happen to have any info on how I could contact him?
    Thanks,
    Tom
  • 01-20-2011 1:03 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Maybe this helps...(?)
    http://www.b-o-specialisten.dk/default.asp?pid=31
    http://www.bbuy.dk/product.asp?product=255
    Stefan
