1st March February 2012
Latest post 06-15-2007 8:23 PM by BeoBeau. 9 replies.
05-02-2007 10:30 AM
SiliconTi
- Joined on 04-17-2007
- Posts 46
How To Refurbish The Shiny Metal Panels On Your B&O
OK, first off, please keep in mind this is what worked for me - it may not work for you. This information is to be used at your own risk - if you destroy your B&O using these directions, it is your own fault. OK, now that that unpleasantness is over:
Products used:
2000 grit wet type sandpaper 1000 grit wet type sandpaper 90% Isopropal Alcohol Water Eagle One Mag & Aluminum Wheel Polish Part #1030605 Turtle Wax Automotive Rubbing Compound Three clean, soft cloths
If you have deep scratches, first use the 1000 grip sandpaper and some water - wet it before using to keep the grit clean and keep it from cutting too deeply. Work in a motion along the longest axis - for example, with my BL 500 hanging on the wall, I worked up and down. A BC 9500 would be worked side-to-side.
After this, (or if you have light scratches) follow with the 2000 grit wet paper- again with water. This is followed by the Eagle One polish - be careful; this product is aggressive and will create a bright shine. If your product is not shiny (the BL 5000s are not, they have a more satin finish). Just polish a little bit at a time, wipe it down (with a clean, soft cloth) and check to see if it needs more. If it is too shiny, I was able to dull it a bit with the Rubbing Compound.
A few strokes with the Polish will clean the parts without polishing them if they are just dirty.
After the above, polish with a very soft cloth, followed by a rub down with a small amount of the alcohol on a clean cloth to remove any residue and fingerprints.
Above all BE CAREFUL. Do just a little at a time as these products can damage the surface if you are not careful.
This is a very time consuming project. Just doing the two BL 5000s took 3 hours, and they were really not that bad. I could spend a few more if I wanted them to look like new.
Hope that helps!
RicardoBathUK
- Joined on 04-19-2007
- Posts 27
Re: How To Refurbish The Shiny Metal Panels On Your B&O
SiliconTi, sounds like a new career!
History - it's just one thing after another!
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
Sounds good if labour intensive. This has been tried on the mirror panels as fitted to the BC9500 & other products from the same era. The problem here being the mirror finish is actually an anodised surface treatment and any abrasive treatment simply ruins them Good for non anodised aluminium & stainless steel surfaces (ala Beolab 5000 panels/penta's) though. Chris.
The Beonic Man
- Joined on 04-16-2007
- Bath
- Posts 426
You may be interested to know that you can use Johnson's baby oil on most metal surfaces to get a beautiful polished finish. Apply a small amount to a slightly damp cloth. Of course this will not remove scratches but it will give you a lovely shiny finish. Simon.
"We can rebuild him. We have the technology."
7-40, 7-2, 9000, BS3, BC2, LC2, BC6000, Beo5
BeoBeau
- Joined on 04-20-2007
- Posts 16
I noticed in one of the Penta manuals that B&O recommended using mild detergent, and after several of these applications (Once the original surface oil has been removed), applying coconut oil.
Medogsfat
- Posts 4,045
Yep, coconut oil is recommended by B&O for Penta panels & great for keeping the original lustre. The original post was really an idea for refurbing panels which were in need of some TLC due to scratches etc... and certainly not as a means of regular cleaning, just thought I should clarify this before we all dash off to B&Q
Dave
- Brisbane, Australia
- Posts 2,328
White oil is the ultimate brushed steel / aluminium cleaner, has anybody tried it? It's wonderful.
When i ran out i tried other oils such as baby oil, canola oil etc. and they did not come close to restoring the finish like white oil does.
auclutch
- Joined on 06-02-2007
- Posts 66
thanks for the cool instructions. since I live in Korea I won't be able to get the exact same products but I'm sure I can find something similar. by chance do you have any pictures of before and after?
BS1 x 2, BS 3, BS4, BS2000 x 3, BS2300, BS4000, BS9000, BL4, BL 4000 x 2, BL8000 x 2, BL2500 x 2, BL2000, Beocom 2, Beocom 6000 x 4, Beocom 1401 x 4, Beocom 1600 x 2, Beocom 2500 x 4, Beotalk 1200, A9 Keyring, Beo4 x 8, Beotime, Bottle Opener
2011 Wish List: BL3500, BL6000, BL5, BL9, active link, BS5, Beo5
auclutch
- Posts 66
by the way, what is white oil and where would one find this? i.e. supermarket, hardware store?
BeoBeau
- Posts 16
Check it out on the internet. It is a pure distillate.
Page 1 of 1 (10 items)
