Latest post 03-10-2008 6:01 AM by joeyboygolf. 2 replies.
Page 1 of 1 (3 items)
  • 03-10-2008 4:45 AM
    • bus55
    • Not Ranked
    • Joined on 12-23-2007
    • Posts 10
    Confused [*-)] beogram 5500 spotlight
    When does the spot light on the record player turn on and can I manually turn it on.
    Thanks.
  • 03-10-2008 4:58 AM In reply to
    • rfc1
    • Top 500 Contributor
    • Joined on 02-06-2008
    • Posts 166
    • Gold Member
    Re: beogram 5500 spotlight
    The light on my 6500 turns on when the stylus arm is lifted off the record, presumably to assist in manually selecting a track.  Havent noticed a means of turning the light on without stylus are "in use" though.
    sandy
  • 03-10-2008 6:01 AM In reply to
    It turns on when the < or > controls are used. There is no way of turning it on in any way manually.
    Regards Graham
