Latest post 03-27-2009 4:29 PM by Dillen. 5 replies.
Page 1 of 1 (6 items)
  • 03-09-2008 5:22 PM
    • Ben
    • Top 500 Contributor
    • Joined on 12-28-2007
    • Taunton, UK
    • Posts 131
    • Silver Member
    Beomaster 800 Lamps
    I just bought an apparently mint 800. Supposedly works great apart from both tuning lamps are out.
    By my reckoning, looking at the service manual, these are LED's, so not very likely to burn out.
    I haven't got the unit yet, so cant tinker. Has anybody had this problem before?
    Regards,
    Ben.
  • 03-09-2008 5:48 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beomaster 800 Lamps
    It's lamps. Three in total and of 2 different wattages.
  • 03-09-2008 6:06 PM In reply to
    • Ben
    • Taunton, UK
    • Posts 131
    • Silver Member
    Yes.... your right as usual. I had a closer look at the service manual. The diodes in parallel with the lamps was confusing me!
    Do you supply these lamps Martin?
    Thanks,
    Ben.
  • 03-10-2008 3:44 AM In reply to
    • Dillen
    • Posts 5,008
    Yes.
    Any good supplier will have them, drop me a PM if you cannot find the lamps locally.
  • 03-27-2009 3:30 PM In reply to
    Dillen:
    Yes.
    hi, i need the green lamps for my beomaster 800...can you supply to uk? and dial cord fro volume slider come to think of it?
    loved your beolit 39 restoration
    thanks
  • 03-27-2009 4:29 PM In reply to
    • Dillen
    • Posts 5,008
    Hi dan1969 and welcome to Beoworld !   Yes -  thumbs up
    Thanks.  Wink
    You have a PM regarding lamps and dial string, check you inbox in the upper right corner).
