Latest post 03-09-2008 8:19 AM by zimp. 4 replies.
Page 1 of 1 (5 items)
  • 03-09-2008 6:52 AM
    • zimp
    • Not Ranked
    • Joined on 03-09-2008
    • Posts 3
    Beogram 3300 Question
    I'd just like to have someone confirm that the beogram 3300 hasn't got a built-in preamplifier as I've understood it? I'd just like to know as I would need to connect it to a Onkyo receiver which doesn't have a phono input, and but i don't want to buy a preamp if I don't need one. Also, if the preamp which I'll buy, if one is needed, has a 5-pin DIN input, is it possible to remove the 1st and 7th pins from the DIN cable coming from the beogram to connect it?
    zimp
  • 03-09-2008 7:15 AM In reply to
    Re: Beogram 3300 Question
    The Beogram 3300 does NOT have built in RIAA so you WILL need a preamp.
    Pins 1 and 7 in the plug should be screwed in and can be removed with a small jewellers screwdriver. However, the majority of commercially available preamps have phono sockets so you will need to either modify the cable or obtain adapters.
    Regards Graham
  • 03-09-2008 7:51 AM In reply to
    • zimp
    • Not Ranked
    • Posts 3
    Thanks for your answer, just what I was hoping to hear. About the preamp though, I've found one which has 5-pin DIN INPUT (rca too) so shouldn't it work just fine with that, without the need to buy an adapter?
  • 03-09-2008 7:58 AM In reply to
    That will be fine. What model of RIAA have you found as knowing one with a DIN socket would be useful?
  • 03-09-2008 8:19 AM In reply to
    • zimp
    • Not Ranked
    • Posts 3
    Thought so. Can't really say much about the preamp though, it's a cheapo one from http://www.vekoy.com/product_info.php?cPath=352_354&products_id=8603 (Finnish site). It doesn't say anything about the producer, don't know if the pic helps.
    Awesome help though, looking forward to listening to some vinyl.
