Latest post 03-07-2008 5:19 PM by Craig. 5 replies.
Page 1 of 1 (6 items)
  • 03-07-2008 2:18 PM
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Beocord 2000 Casette Deck
    Having problems with a  Beocord 2000 I brought as non working. First problem was the drive belts had stretched, which seems a common problem. Got some new belts from Martin and I thought all was O.K. Then I tried to record and play back a cassette. All I could hear were a series of clicks. Tried a pre-recorded tape and still the same. My first thought was that the head was no good. changed the head and I still have the same problem. So over to our experts please.
    CraigSmile
  • 03-07-2008 2:59 PM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocord 2000 Casette Deck
    Do you have a constant max VU reading during play ?
  • 03-07-2008 4:13 PM In reply to
    • Craig
    • Posts 4,855
    Yes Martin. Seems like you know just what is wrong.
    CraigSmile
  • 03-07-2008 4:16 PM In reply to
    • Dillen
    • Posts 5,008
    Yes. Big Smile
  • 03-07-2008 4:18 PM In reply to
    • Dillen
    • Posts 5,008
    You will find that the 8Vref is down, causing the VU to go to full scale and the Beocord to mute.
    Replace the black radial capacitors on the top circuit board. I think they are 220uF. Put in 25V components instead of the original 10V or 16V ones. One of them (or more) will have shorted.
  • 03-07-2008 5:19 PM In reply to
    • Craig
    • Posts 4,855
    Thanks Martin, i will see if I can find any.
    CraigSmile
