Latest post 03-11-2008 11:22 PM by Rapidroy. 20 replies.
Page 1 of 1 (21 items)
  • 03-07-2008 12:35 PM
    what size is the plug of a Beocenter 9000 relay socket?
    Hi All
    I want to add an amp to my 9000 and want it to trigger the amp with the 12v relay socket (part # for the cable is 4002) anybody know the size plug is need?
    Roy
    Roy Albuquerque, NM
  • 03-08-2008 6:01 PM In reply to
    Re: what size is the plug of a Beocenter 9000 relay socket?
    Anyone know? BUMP
    Roy Albuquerque, NM
  • 03-09-2008 4:16 AM In reply to
    Where are you Rapidroy? I do have a type no 4002 mains relay kit, if only I could find it!. PM me if you are interested in buying and I will have a clear out.
    Regards Graham
  • 03-09-2008 11:55 AM In reply to
    Hi
    I'm in Albuquerque, NM. My big plan is to add a AudioSource AMP300 and preamp it with the Beocenter 9000 to power my Acoustat Model 4's. Right now I'm using my Sansui G-6700 to power the Acoustat's but it really does not like the 2ohm load. I put a call to a B&O place it California and he said he'll look to see if the kit was still around. But if you find yours I'm sure we can make a deal.
    Roy Albuquerque, NM
  • 03-09-2008 12:15 PM In reply to
    Rapidroy:
    Hi
    I thought you might be "across the pond". In which case I believe you will need the 120 volt version which I think was a type 4001 remote mains switch.
    Regards Graham
  • 03-09-2008 1:03 PM In reply to
    • Ben
    • Top 500 Contributor
    • Joined on 12-28-2007
    • Taunton, UK
    • Posts 131
    • Silver Member
    I might be interested in this kit if it works with a Beomaster 5000.
    Please let me know.
    Cheers,
    Ben.
  • 03-09-2008 1:34 PM In reply to
    Hi Graham and others.....i'm curious....how does this 4002 or 4001 kit work??? What's the basic principle??  Thanks !!
  • 03-09-2008 1:35 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Ben, I believe the only two products it would work with were the Beocenter 9000 and the Beomaster 5000. For using it with other products you needed a special lead which conected to the Powerlink sockets.
    CraigSmile
  • 03-09-2008 1:41 PM In reply to
    • Ben
    • Taunton, UK
    • Posts 131
    • Silver Member
    If this kit is no good for Roy, i'd be interested if its still available.
     I'm using external power amps on my Beomaster 5000, and was thinking this would save me having to power them up and down seperately.
    Thanks,
    Ben
  • 03-09-2008 2:06 PM In reply to
    Frank Rizzo:
    It's a 12 volt relay which when powered from a socket on the Beocenter 9000 can be used to power on external devices such as power amps. I used it when I had the Quad 405 with my BC9000. It has a timer facility as well although I never quite got the hang of that.
    Regards Graham
  • 03-09-2008 2:10 PM In reply to
    ben12345:
    Thanks,
    Ben
    As there is no dedicated socket for this device on the BC5000 you will need to arrange a 12v supply from the Beocenter which will trigger the device when the Beocenter play function is activated. It could be done and there is a socket included with the kit for just this eventuality.
    Regards Graham
  • 03-09-2008 2:22 PM In reply to
    • Craig
    • Posts 4,855
    Acording to the user manual the Beomaster 5000 does have a dedicated connection for the relay.
    CraigSmile
  • 03-09-2008 3:11 PM In reply to
    Craig:
    CraigSmile
    I should have checked, thanks Craig. So the 4002 should work out of the box!
    Send me a PM Ben, if you are interested in it.
    Regards Graham
  • 03-09-2008 6:31 PM In reply to
    • PL212
    • Top 200 Contributor
    • Joined on 02-14-2007
    • Moderator - Seattle
    • Posts 318
    joeyboygolf:
    I have the North American version of this and, as near as I can tell, the "TIMER" indicator on the front is just to let you toggle between having the outlet controlled by the BeoCenter and having it powered all the time.
    As others have noted, you can use this with modern, PowerLink equipment by use of a simple breakout cable that B&O has.
    However -- and I'm not sure if this is important in GB -- the outlet on the back is non-polarized, at least on the 110v version. It's hard finding equipment that will plug into a non-polarized outlet nowadays.
  • 03-09-2008 10:00 PM In reply to
    Very cool....thanks Graham !!!!!!
  • 03-09-2008 10:56 PM In reply to
    Well, I found a barrel type plug thats fits the 9000 so I think I can tap the 12v and send it to the amp to fire its relay.
    Roy Albuquerque, NM
  • 03-09-2008 11:07 PM In reply to
    Hey Roy...you're not too far from me ...i'm in Colorado..
  • 03-10-2008 12:24 AM In reply to
    Hi Frank
    Are you in Denver? I got some parts from a place in Denver that services B&O but I can't remember the name or phone # would you have that info?
    and to anyone that knows, does the 4001 or 4002 (i found a photo of it on this web site) just triggers 1 ac outlet ie. you plug the 12v wire to the 9000 and then you plug the 4001 to ac then you plug 1 thing like a amp or lamp to it? and then when the beocenter is turned on it sends 12v to a relay in the 4001 which sends power to the ac outlet.
    Roy Albuquerque, NM
  • 03-10-2008 1:16 AM In reply to
    Hey Roy....yep its the Gramophone Shop (303) 744-1284..
     Send us a link so we can see the pic of this thing>....Thanks...
  • 03-10-2008 1:41 AM In reply to
    Rapidroy:
    That's correct Roy.
    Regards Graham
  • 03-11-2008 11:22 PM In reply to
    I'll post a photo once I get the amp and everything setup. Thanks for the info for the shop in Denver.
    Roy Albuquerque, NM
