Hi Mika,
You are correct that I replaced the bulbs with LED's.
However, this did not cause the problem, but actually identified a pre-existing problem.
Here's how:
When I bought the BG6000 last year, the 33 indicator light never illuminated - I thought it was burnt out (when I put in the LED's, I looked closely, and saw that it was actually not burnt out - just one lead not soldered!!!).
The 45 light did work, and it illuminated at all the correct times, so, the speed switching worked fine.
Because of the heat damage on the white plastic, I never got around to replacing the 33 bulb, intending to put in LED's at some stage.
Now, when I put in the LED's, and therefore completing the 33 circuit, the problem showed itself.
Now I measured the voltage on both sides of the bulbs - 22.1V on the power supply side, and 17V on the Flip-Flop Circuit side.
My first thought was - yes the LED's have caused the problem - the LED is taking too much voltage - 5V , so I must go back to regular bulbs.
So I took out the LED's and resistor, and soldered in both bulbs again.
I pressed the START button, and the problem still existed as above - 33 for a split second, and then remains at 45.
The only difference is that now there is 21.8V on the flip-flop circuit instead of 17V.
So I figured, OK, let's disconnect the 33 bulb (like when I bought the BG6000), and see what happens.
With the 33 bulb disconnected, everything works as it should!!!!
So there is a problem in the 33 circuit, whether or not there are LED's!
It now appears that this problem existed before I bought the BG6000, and a previous technician found this novel solution to solve it - just disconnect the 33 bulb.
D5, C3 (new Wima MKS2), TR2 all OK.
So, any ideas here?
Also, I have never seen this large IL1 bulb on this Control PCB illuminate - what is its function, and when should it illuminate? It tests OK, so it is not burnt out.
I will go back to the LED's again, probably on a modified circuit (to not take so much voltage), but not until I have this speed problem solved!
Regards
Menahem
Learn from the mistakes of others - you'll not live long enough to make them all yourself!
