hi there,
 I have been reading many posts concerning getting AppleTV to work with Beovision 7-32 Mk III, including being able to control it using the Beolink 4 ... my questions are:
1) How can I see if I have a Mk II or Mk III series (and btw. what is the difference?)
2) Does AppleTV only work with Mk III or also with Mk II? Can a Mk II somehow be upgraded to work?
3) What software versions are required on the Beovision?
4) What kind of programmation is needed to make it work? Is this something I can do, or is it dealer only?
Thanks,
 Jesper
