Latest post 03-10-2008 4:12 PM by martin01. 16 replies.
Page 1 of 1 (17 items)
  • 03-06-2008 6:44 AM
    Latest Sw for Beovision 7-40 Mark III
    Hi, Which is the latest sw for BV7-40 Mark III? I have recently upgraded my 7-40 with sw 4.0. I have heard that there is a sw 4.12. What will this new sw fix?
    /Martin
    Beolab 5 with sw 3.0,  BV7-55 3D without Bluray(MK II), Beolab 7-4, Beolab 4000 MKII, Beolab 3500, Beovox CX100, Beosound 9000 mkIII, Cabinett 2054, Beo4 MKII, Oppo BDP-93 Blurayplayer (B&O-version)
  • 03-06-2008 7:14 AM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Re: Latest Sw for Beovision 7-40 Mark III
    martin01:
    I know sw 4.01 was released in early February and that's what is installed on my TV. Beolab mentioned that sw 4.03 (with 24fps support) was due soon, but not heard anything since. Are you sure they're on 4.12 already, in less than a month since 4.01?
  • 03-06-2008 7:55 AM In reply to
    Do you really think that 4.03 sw will support 24 frames? I thought Beosystem 3 had to be hardware-upgraded. Does anybody know if B&O can confirm this with 24fprs with software 4.03?
    /Martin
  • 03-06-2008 2:59 PM In reply to
    Got my set last Friday and have today updated the software to 4.12 , also put in Ps3 ( via a NYKO ) , Ipod and Sky Hd  control software , don't know what can be done with the Ipod yet . Forgot to ask about 24fprs , but will find out tomorrow .
    Richard
  • 03-06-2008 5:46 PM In reply to
    • JoC
    • Top 500 Contributor
    • Joined on 08-20-2007
    • Northern Ireland
    • Posts 121
    Has the latest software definitely fixed the white flashing issue with 1080p content.
    I just bought a PS3 at the weekend and have indeed spotted this problem with Blu-Rays, 1080p based games and up-scaled media from the NAS. It is a tad annoying, but sometimes I forget about it after a while (maybe I just tune it out). I only ask this because the dealer wants to charge me for upgrading the software. So if it fixes the issue (and adds other features), I may have to pay the money.
    JoC
  • 03-07-2008 2:06 AM In reply to
    JoC:
    JoC
    No still the same on my BV9Super Angry
  • 03-07-2008 2:42 AM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    JoC:
    JoC
    You shouldn't have to pay anything for a 'faulty' TV. These white flash issues do not happen across other brands (I've tried the PS3 on a Sony and Samsung, without issues), so it's a B&O issue with their 1080p screens. I'd tell your dealer he can have the TV back if he can't fix this issue and threatens to charge for attempting to fix it.
  • 03-07-2008 4:40 AM In reply to
    so, the BV9 has the same "flash"-problem? Why haven´t we heard about this before? Is it so few Bluray-users out there?
    It would be interesting to know if the latest sw 4.12 will fix the flash-problem AND 24fprs-"problem".
     /Martin
  • 03-07-2008 6:17 AM In reply to
    martin01:
     /Martin
    I have 4.12 and still the same :-(
  • 03-07-2008 6:33 AM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    martin01:
    As I've mentioned before, the 4.03 sw upgrade fixed the white flash problem on Blu-rays for me, but I still see the flash on the PS3 controller screen and PS3 1080p games. It seems it's a 1080p problem.
  • 03-10-2008 7:03 AM In reply to
    To Mr Andersson: If you have sw 4.12, do you know if your BV7 does support 24 fprs?
    I have heard that there are a lot of "bugs" in this sw. Have you experienced this?
    /Martin
  • 03-10-2008 8:12 AM In reply to
    martin01:
    /Martin
    I have BV9, but has not "seen" any bugs
  • 03-10-2008 10:58 AM In reply to
    Does your Bv9 support 24 fprs, meaning does it fully support bluray-movies with 1080p/24fprs with software 4.12?
    /Martin
  • 03-10-2008 11:45 AM In reply to
    Hmm I dont know. How can I see that? I have PS3 as Blueray
  • 03-10-2008 11:53 AM In reply to
    You can see it when you are looking at bluray-movies when you look at moving objects at the screen. If you se some "jerking" movements in the picture you DON´T have 24 fprs support. But if all movements in the picture (large movements, typ panorama movements) is smooth, then you should have 24 fprs-support. Check it and let me know.
    Regards
  • 03-10-2008 2:18 PM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    Martin, are you absolutely sure? I don't see jerking on most movies apart from Ocean's 13 and that's also present on the SD DVD.
    I don't think we can deduce whether we have 24fps support just from watching a Blu-ray (I wouldn't be able to come back to you and say yes/no, either way). We need a bug update list. Beolab or Coolskin usually have this info..
  • 03-10-2008 4:12 PM In reply to
    I have posted a letter to B&O and asked them if the new sw 4.12 will support 24 fprs. I havent got any answer yet. But YES, if you look at some bluray movies (except from oceans 13), you can see small jerking movements in the picture when you look at slow panorama movements. This has got to do with that the BV7 has to make a 3:2 pulldown, which means that the TV has to put one extra frame every second time it updates the picture. When a bluraymovie is recorded in 24 fprs you need a tv that support 24/48 or 96 fprs to get a smooth picture. BV7-40 mark III just supports 50 and 60 fprs. I have asked B&O about this but they just say that the tv supports 25 fprs which is right (half of 50 fprs). They recommended me to get a bluray player that supports 25 fprs. They dont know that all bluraymovies are recorded in 24 fprs. That is really bad that a premium brand dont know about this, or maybe it is just the people at custumerservice that dont know this technical stuff.
