Latest post 03-03-2008 11:19 AM by frankmj. 10 replies.
Page 1 of 1 (11 items)
  • 03-02-2008 8:56 AM
    BeoLab 10
    Do you think it could replace the 7-2 and work with my BV7-40? If this is an option it is one I would definitly take to achieve an AV9000 look.
    Simon.
    "We can rebuild him. We have the technology." 7-40, 7-2, 9000, BS3, BC2, LC2, BC6000, Beo5
  • 03-02-2008 8:58 AM In reply to
    • Tom
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    Re: BeoLab 10
    I have asked the same question on this forum some time ago and the answer was that the BL10 would not fit the BV7, only BV4.
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 03-02-2008 9:11 AM In reply to
    Re: BeoLab 10
    What a shame. Thanks for the info Tom.
  • 03-02-2008 9:12 AM In reply to
    Re: BeoLab 10
    The kittens have sent a saucer of milk over to Gavin at STB Brackets to hopefully entice him to build a bracket adaptor.
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 03-02-2008 10:41 AM In reply to
    Re: BeoLab 10
    If you look at BeoLab 10's user guide, you see it has the same sound settings as other BeoLabs, i.e "free" and "wall". The "free" setting is said to be "for future use", because BV4 is only wall-mounted: that clearly means that BeoLab 10 will be able to work with free-standing TVs, like BV7, because I don't see a 500 Kg BV10 in a free-standing mode..[:'(]
    Reunion Island is greeting you!
  • 03-02-2008 1:32 PM In reply to
    Re: BeoLab 10
    I've seen and listened to the BL10 and I was told it will be possible to fit this to a BV7. I had a look under the front cloth and It's only one speaker element (5-6") directly under the ALT-lens. (The BL 7-4 has two I think). About the sound, It was quite OK. The system was the new Full-HD BV4 with seven BL9!
    /Ola
  • 03-02-2008 2:52 PM In reply to
    Re: BeoLab 10
    Ola,
    Your avatar caught the kittens' attention. They hope he/she is friendly.
    For clarification, the BeoLab 7-4 has one driver under the AL. The BeoLab 10 is identical in terms of electronics.
  • 03-02-2008 3:11 PM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    Re: BeoLab 10
    B&Ola:
    I've seen and listened to the BL10 (...) The system was the new Full-HD BV4 with seven BL9!
    Why where there 7 BL9 and a BL10? 6 BL9 and a BL10 as center makes better sense.
  • 03-03-2008 8:06 AM In reply to
    Re: BeoLab 10
    Update from B&O: I have been advised that the speaker will work with the BV7 and come with the relevent brackets. In dealers from March 27th onwards.
    Simon.
  • 03-03-2008 10:40 AM In reply to
    Re: BeoLab 10
    Hi!
    OK, they told me that the BL7-4 had two units under the ALT but they were obviously wrong. The lady who told me was from the Swedish HQ.
    About the number of BV9, what I could remember there was one BL9 standing in the center back of the sofa, two "back" two surround and two front and then the BL10 and two BL2.
    But as you say Daniel, it seems strange to have a center back?
     /Ola
     (And yes, my avatar, Dutchie is VERY friendly)
  • 03-03-2008 11:19 AM In reply to
    Re: BeoLab 10
