Latest post 03-06-2008 4:40 AM by Jackplug. 3 replies.
Page 1 of 1 (4 items)
  • 03-01-2008 8:13 AM
    CD 7000
    Hello - I have misplaced the cardboard insert placed in the tray when shipping (I do have the "screws.") I plan on selling the unit and am concerned about not having it. Is it essential and if so, would anyone have a tracing of it so I could construct one?
     Thanks.
    Filed under:
  • 03-01-2008 9:28 AM In reply to
    Re: CD 7000
    If you have the tray locks I think you will be fine. Never had the tray insert myself!
  • 03-01-2008 11:55 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: CD 7000
    Me neither! never heard of or seen the insert. I wouldn't worry personally as they seem to travel fine without it.
    Chris.
  • 03-06-2008 4:40 AM In reply to
    Re: CD 7000
    I can send you a tracing of mine for the CD5500 which might be OK?  The card is about 2mm thick max.
    Jack
    BV10(40) BV8-32, BV3-32, MX7000, DVD1, HDR1, V8000
    Beomedia-1, BS9000, BC7002, BC2300, BS5500, BM6500, BGCD6500, BM1900-2
    BL5, BL8000, BL6000, BL Penta3, BL3500
    Beovox MC120.2, 3000 Panels, CX50s, C75s, AND LOTS WIRES, BOOkS, MAGS n BITS (ebay sales: beo-store-uk)
