Latest post 03-01-2008 7:25 AM by Roger. 4 replies.
Page 1 of 1 (5 items)
  • 02-29-2008 5:56 PM
    BeoCen 6-23
    Can any B&O TV be plugged into an Apple Mac computer? I have noticed in a few of the showrooms that they use the Beovis-8 and Beocen-6 as monitors but I have tried to plug in my mac laptop and gone through all the setup with the B&O TV, there is some sort of recognition but not a correct connection... Is there anyway to make the mac connect with the B&O at the moment it does seem to be the mac's end that is causing the problem....
  • 03-01-2008 2:00 AM In reply to
    Re: BeoCen 6-23
    That shouldn't be a problem. I connect my Macs with ease to my BV8.
    Here's what you should do. Get a DVI-to-HDMI converter cable. (DVI is the video protocol of HDMI, and is the same plug that is in your Mac to drive an external screen.)
    The HDMI connector goes into the BV.
    Then in setup you need to assign the source properly. If you're using a Beo4, then just add PC to LIST; and in the setup menu on the BeoVision, you tell the television that PC means the HDMI input.
  • 03-01-2008 2:27 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    Re: BeoCen 6-23
    The BeoCenter 6-series do not have the HDMI input - only DVI.
    On the 6-23 you get the picture on the screen by pressing "PC" on your Beo4. Then you need to pull up the DVI SETUP menu (press MENU) to adjust the settings for the DVI-input. Your PC (sorry, Mac) should be set up with the correct resolution for the external display (1366x768).
    Roger
  • 03-01-2008 3:30 AM In reply to
    Re: BeoCen 6-23
    There you go. I shouldn't have taken it for granted that it would have HDMI in like the BV8, but same procedure, right? You'll need a DVI-to-DVI cable, then.
  • 03-01-2008 7:25 AM In reply to
    • Roger
    • Norway
    • Posts 870
    Re: BeoCen 6-23
    Yes, the same procedure - I guess quite a few customers do not know how to pull up the setup menu that can be accessed on recent BeoVision's (as stated by Soundproof - you can also state that HDCP should be handled by HDMI if that is your connection, BV8, 7-40 mkIII etc).
    Roger
