Latest post 05-04-2007 9:30 PM by Corvin. 48 replies.
Page 2 of 2 (49 items) < Previous 1 2
  • 05-02-2007 2:26 AM In reply to
    Re: Beo 5 : Discuss!
    mobeyone:
    So........ is the remote robust enough for every day usage?
    Given your problems just lately Mobe, probably not!!!Laughing
    Regards Graham
  • 05-02-2007 5:22 AM In reply to
    joeyboygolf:
    mobeyone:
    Tell me about it!!!! I am waiting for something else to go wrong!
  • 05-02-2007 5:34 AM In reply to
    • Christian
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 626
    Justin:
    Also, is the LCD touchscreen backlit - I can control a Beo4 in the dark, but with a touchscreen its somewhat harder!
    Yes it is completely backlit, also the keypad. There is no LIST button (as far as I remember), all options are available on the screen.
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 05-02-2007 6:11 AM In reply to
    The color keys are also the Play/Pause etc keys... how do you choose between one or the other?
     There seem to be a wheel, what is it used for?
     There is also a navigator in the middle, is it used for menus on the remote? Where I am a little bit confused is that on the Beo4 the FF and Rewind keys and Up and Down are used for the navigation and here they seem to be different keys...Confused
     ph.
  • 05-02-2007 7:06 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    wtlc2zpx:
    Volume!
  • 05-02-2007 5:21 PM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    On the screen you can have a logo for each TV channel instead of the number. Looked very cool and felt very B&Oish!
  • 05-03-2007 3:41 AM In reply to
    Thanks a lot for the information....
    Perhaps somebody can answer my questions...
     - when will the beo 5 hit the market
     - i have different information - is it possible to learn codes from other devices ( ps 3 or apple tv )
  • 05-03-2007 3:56 AM In reply to
    • Christian
    • Posts 626
    ESTIMATED launch: Fall '07, so it should be end '07.
    I do not think it will be possible to lean codes, from another remote, but the dealer will program the Beo5 for you, if B&O knows the product, or you supply them with a list of IR codes.
  • 05-03-2007 4:00 AM In reply to
    Praetorianer:
    Fast scrolling on the aTV would be great - is this possible on a learning remote or is this a complicated macro?
  • 05-03-2007 8:52 AM In reply to
    did someone bring up 2-way system discussion of future products?
    it might be that new remote ready for 2-way system also (?)
  • 05-03-2007 9:05 AM In reply to
    • Kevin
    • Joined on 02-15-2007
    • Moderator
    • Posts 1,256
    Yes we did ask and many more questions which were politely recieved with a smileSmile I think we need a few surprises in lifeCool
  • 05-03-2007 11:41 AM In reply to
    • Alex
    • Top 500 Contributor
    • Southern CA
    • Posts 137
    wtlc2zpx:
     ph.
    The color keys are actually on the play/pause etc but you dont hit those buttons if u want to use the color keys, you actally push down on the wheel where the color is (think of serene for OK, C, Green and Red). The center arrows are used for navigation of menus on screen, like a guide on your satelite and stuff like that. The arrows around the wheel are to change channels, fast forward and rewind.
    Had a lot of training on it, it is honestly a great product, they said no 2 way communication but you never know. You can also add 3rd party products via the PUC directly into the remote.
     It is fully customizable. A sure hit im sure.
    -Alex
  • 05-03-2007 12:24 PM In reply to
    Alex:
    wtlc2zpx:
     ph.
    You are sure with the 3rd party products, so i can use the beo5 for my apple tv and ps 3....?
     Thanks for help...
  • 05-03-2007 3:58 PM In reply to
    • Alex
    • Southern CA
    • Posts 137
    The PUC was just updated to control the Apple Remote, so yes the BS3 and the Beo5 will be able to control AppleTV. As far as PS3 goes if it is IR compatible yes it can be done but keep in mind that the updates can only be done by B&O, Beo5 cannot learn codes.
    -Alex
  • 05-03-2007 4:31 PM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    The PS3 uses Bluetooth to communicate, and I haven't haerd of any IR capabilities. It's possible though that they have added this as an extra (you'd expect them to, considering the price).
     Weekly top artists:
  • 05-03-2007 6:19 PM In reply to
    Alex:
    Do we know if that includes fast scrolling?
  • 05-03-2007 8:50 PM In reply to
    • Corvin
    • Australia
    • Posts 124
    I mentioned in a thread a few days ago that i have my PS3 working with IR control. There is an OEM remote and base available which is connected to the PS3 via one of the USB ports.
    Mine is working well with my Beo4 using a Lintronic box, so it is possible although the functions available are limited to the basics. I hope in time that this will be expanded on.
  • 05-04-2007 10:33 AM In reply to
    • frog
    • Joined on 04-19-2007
    • Posts 191
    Alex:
    Now I'm puzzled - earlier posts say that it can be programmed by the dealer or by yourself.
     My guess is that it is programmable exactly like a Pronto via the USB port and can output 455Khz and 40Khz IR.
  • 05-04-2007 10:45 AM In reply to
    I wonder if the STB-C of my BV-7 can also be upgraded to handle the Apple codes??? How much does it cost to upgrade the STB-C software on a BV7?
     I thought the STB-C is a better idea than a programmable remote for these reasons:
    - The ugly non box set-top bax can be hidden
    - It works from link rooms
    I wonder in the Beo5 is able to actually tell the STB-C to emit the code rather than emiting it itself...
  • 05-04-2007 1:49 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    frog:
    Alex:
    Hi Frog. The impression I got in Struer is that, to start with, programming will be done by your dealer but as everything gets sorted out and any little glitches ironed out then we will be able to do it ourselves.
    Andy T.
    Poor me, never win owt!
  • 05-04-2007 2:15 PM In reply to
    Regarding the two way possibilityBig Smile from what people are saying this sounds like a new method for two way comm? and not similar to say the method (right word?) used by the old school remotes?
    So... if the remote is sold can it still be upgraded at a later date to two way? like a module replacement etc?
  • 05-04-2007 5:10 PM In reply to
    Praetorianer:
    The PS3 is controlled via Bluetooth
  • 05-04-2007 9:30 PM In reply to
    • Corvin
    • Australia
    • Posts 124
    Yes, internally but as i have said earlier it is possible to control (limited) the PS3 with IR via USB interface.
