Latest post 02-28-2008 12:53 PM by MoglesMac. 1 replies.
Page 1 of 1 (2 items)
  • 02-28-2008 11:55 AM
    • meling0017
    • Not Ranked
    • Joined on 11-18-2007
    • Stavanger, Norway
    • Posts 18
    • Silver Member
    CD 5500 tray closes to fast/by itselves
    I have a problem with the CD tray on my Beosystem 5500 CD unit. When opening the tray it comes out normally but then it closes again by itselves often before I manage to insert the CD. Normally it shall stay open until you slightly push the tray or push the open/close button. Is there anything I can adjust or do to fix this. I have the manual and I have no problems to get innside the unit but I do not know what to look for or what actually controll this function. Anyone that can give me some guidance here.
    Filed under:
  • 02-28-2008 12:53 PM In reply to
    Re: CD 5500 tray closes to fast/by itselves
    I had similary problem with my CD5500, see my post here:
    http://forum.beoworld.org/forums/thread/79685.aspx
    However since then it have started to missbehave again :(, not as bad since before but sometimes it closes too fast. All i did was touch the 90S1 jumperswitch as i describe in above post but its no permanent or even sure fix tho :(
    Cheers
    Jesper L   / Sweden (with no magic fingers)
