Hi, and welcome to Beoworld. Do I take it from you post that your turntable is running slow. This is a common problem with older turntables. What happens is the grease in the motor dries out and form a rather effective glue. This causes the motor to run slow. What you need to do is strip the motor down clean all the parts in Isopropanol for 24 hrs then reassemble, lubricating the parts with Sewing Machine Oil. Do not use 3 in 1 oil as the anti corrosive additives make it acidic. Did this myself to a Beogram 1203, so it must be an easy job to do.
Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
