Any idea what's the cost is of a B&O IR sensor?
I need only a reciever to add to the Beoport.
Anders Odlund has updated the (Mac) BM-Link software to 1.5
This enables my (old) Mac Mini to use FrontRow on the BV7
I've tested it with the TT-IR-8087030 from Lintronic.
Works perfect.
quote
TT-IR-8087030 is a plasma-protected (B&O designed) 455 KHz infrared receiver, to be used as external receiver in environments with a plasma screen, to filter out the infrared noise from the plasma screen, which otherwise disturb/interrupt the reception of B&O signals.
http://www.lintronic.dk/InfraRedReceivers.htm
unquote
