Latest post 04-29-2011 11:10 AM by bluemike. 8 replies.
Page 1 of 1 (9 items)
  • 02-27-2008 9:09 AM
    • majand
    • Not Ranked
    • Joined on 02-26-2008
    • Helsinki
    • Posts 72
    • Gold Member
    Avant and MPAV 9000
    another question about my new Avant.
    I might be able to obtain a MPAV 9000, or Master Panel AV9000. If my Avant had a surround unit attached to it, is it possible to connect that MPAV 9000 to my Avant? If so, do I need a Master Link cable or something which goes to some input sockets near Power Link sockets?
    And if the above is OK, can I control the whole set with Beo4, or do I need the Beolink 5000?
    (I'm not near the Avant now, so can't check the sockets)
    Thanks again,
    Pekka
    Filed under:
  • 02-27-2008 9:12 AM In reply to
    Re: Avant and MPAV 9000
    I think the short answer is no, the software or drivers required to operate the MP are built into the AV9000.
    Someone will confirm for sure.
  • 02-27-2008 11:18 AM In reply to
    You are correct mobe.
  • 02-27-2008 12:42 PM In reply to
    • Ulf
    • Top 100 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 665
    Sorry for not.
    it works, but no Display and settings....
    Only LOAD and LIGHT give a response.
    Ulf
  • 02-28-2008 4:59 AM In reply to
    • majand
    • Not Ranked
    • Helsinki
    • Posts 72
    • Gold Member
    OK, so Beo4 won't work?
    But can I use the MPAV9000 directly, from buttons and get the sound out from Avant?
    Pekka
  • 02-28-2008 5:14 AM In reply to
    • Ulf
    • Germany
    • Posts 665
    No,
    Beo4 works but no Buttons and no Display at the MPAV
    Sound for all Sources RADIO,CD and TAPE works.
    Ulf
  • 02-28-2008 3:43 PM In reply to
    • majand
    • Not Ranked
    • Helsinki
    • Posts 72
    • Gold Member
    Ulf, I'm a bit confused now, maybe, because I've never seen the MPAV in function.
    So, would it be a good idea to buy the thing to go with Avant?
    In the Avant manual there is a device connected to Avant, which looks like MPAV, but might be some other device. Is there a better option?
    How about adding pair of Beolab 4000 into setup?
    I have to admit, that I've dropped off a bit from B&O development. My experience and love to B&O dates to my trustworthy Beomaster 1900-2 and Beovision 601 era.
    Pekka
  • 02-28-2008 3:58 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    majand:
    What you can see is the manual is probably a Beosound Ouverture. This is what the MPAV9000 is based on.
    BEOSOUND OUVERTURE
    CraigSmile
  • 04-29-2011 11:10 AM In reply to
    did you manage to hock up the mpav9000 to your avant?
    if so how???
    thx
    /m
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
