Is it possible to (software) update a DVD-controller type 4021, sw 1.1 to the latest supported list of dvd-players/recorders?
/Rasmus
Avant CTV 28", V6000, DVD1, BC9000, BS3000, BL4000, MX4200, CX50, BeoCom 2, Beocom 6000, LC1, LC2
No, not to my knowledge - the latest sw can only be used on 4046 and 4047 (aka the mkII).
Roger
What are the difference between 4046 and 4047?
Are they 2 or 3 different version?
The 4046 is for EU countries and the 4047 is for the UK.
The actual controller is the same, its just the 5 volt power supply which is different
Regards Keith....
I think you will find that this is the Mark I version.
There is only two versions of the DVD controller.
