Latest post 04-07-2008 4:05 PM by Jandyt. 5 replies.
Page 1 of 1 (6 items)
  • 02-26-2008 12:30 PM
    • riis
    • Top 500 Contributor
    • Joined on 05-01-2007
    • Denmark
    • Posts 152
    MX 7000 and Beolink 1000
    I've just purchased a MX 7000 without remote controller. I've made the necessary adjustments with a borrowed Beo 4 and plan to use my Beolink 1000 to control the tv in the future. Where can I find a list of Beo 4 commands "translated" into Beolink 1000 commands. I've downloaded the MX 7000 user manual, but it only refers to the commands by the Beo 4.
  • 02-26-2008 1:01 PM In reply to
    Re: MX 7000 and Beolink 1000
    Beo 4    Beolink1000 MkI & II    Beolink 1000 MkIII & IV
    [red]        [SHIFT] [<]                   [SHIFT] [\/]
    [blue]       [SHIFT] [>]                  [SHIFT] [/\]
    [green]     [SHIFT] [<<]                [SHIFT] [<<]
    [yellow]    [SHIFT] [>>]                [SHIFT] [>>]
    [MENU]    [SHIFT] [TEXT]              [MENU]
    [LIGHT]    [SHIFT] [LINK]              [LIGHT]
    [GO]        [PLAY]                          [PLAY]
    [DTV]      [SATELLITE]                  [SAT]
    [DVD]      [SHIFT] [CD]                [SHIFT] [SAT]
    [PC]         [SHIFT] [STORE]           [SHIFT] [STORE]
    [DVD2]    [SHIFT] [V.TAPE]           [SHIFT] [V.TAPE]
    [V.AUX]    [SHIFT] [TV]                 [SHIFT] [TV]
    [A.AUX]    [SHIFT] [RADIO]           [SHIFT] [RADIO]
    "N.RADIO"    [PHONO]                   [PHONO]
    "N.MUSIC"    [SHIFT] [A.TAPE]       [SHIFT] [A.TAPE]
    [STAND]       [PICTURE]                [PICTURE]
    [SPEAKER]    [SOUND]                  [SOUND]
  • 02-26-2008 1:04 PM In reply to
    • riis
    • Denmark
    • Posts 152
    Great!!!!! Thank you very much Smile
  • 04-07-2008 3:35 PM In reply to
    • z3kar
    • Not Ranked
    • Joined on 04-05-2008
    • Posts 2
    • Silver Member
    I am using Beolink mk III/IV with MX7000 type 7800 sw 3.1.
     I can't use "Stand" with "picture" same goes with the "sound".  For adjusting the stand I have to go all the way though Menu-setup-.......
     Any hints?
  • 04-07-2008 3:46 PM In reply to
    • Foxtrott
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Vienna, Austria
    • Posts 500
    Hi z3kar!
    This is an SW issue, the SW 3.1. is Beo4 specific and there is the source of your problem. When B&O changed to the Beo4 they implemented the "STAND" command that cannot be emulated on the Beolink1000 (same for the "SOUND" command afaik).
    So if you want to use the stand you have to get a Beo4. Adjusting the sound should work via the Sound Menu.
    cheers
    Foxtrott
    "The first thing we do, let's kill all the lawyers."
    Henry VI, Part 2 William Shakespeare
  • 04-07-2008 4:05 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Hi z3kar
    When in TV/Sat mode, try----  Picture,Picture, >>
    Andy T.
    Poor me, never win owt!
