Latest post 08-30-2008 12:09 PM by sput1. 3 replies.
Page 1 of 1 (4 items)
  • 02-26-2008 11:11 AM
    • aleqss
    • Not Ranked
    • Joined on 02-26-2008
    • Posts 1
    Beogram 1200 Speed adjustment
    I'm quite new at this site and I'm posting this because last week I started to fix an old Beogram 1200 that I had in my storage.
     http://www.flickr.com/photos/alexandrecunha/2273348709/
    Everything seems to be fine with the turntable but rotates a bit slower than it should. 33RPM is now about 30RPM.
    Does anyone have experience adjusting the Beogram 1200 speed? Any useful tips? How do I reach to the belt?
    Thank you,
    Alex
    Filed under: ,
  • 08-25-2008 4:24 PM In reply to
    • Mohawk
    • Top 500 Contributor
    • Joined on 01-30-2008
    • Sweden
    • Posts 103
    • Gold Member
    Re: Beogram 1200 Speed adjustment
    Hi Alex!
    If I remember right there is a speed adjustment thumbwheel on the left side of the record player in the lower part of the chassis, no need to open. You can reach the belt by removing the turntable gently.
    /Fredrik
  • 08-25-2008 5:06 PM In reply to
    There is a speed adjustment though it may be that the speed could be slow for a couple of other reasons. Check the belt - this is a round section belt and can be loose. They are available through specialists but are expensive! You can perform minor surgery by removing a small piece and sticking the two ends with super glue - but this is last resort time! Does the motor speed up with time? If so, it needs stripping down as the grease and oil has become thick. Specialist job really.
  • 08-30-2008 12:09 PM In reply to
    • sput1
    • Not Ranked
    • Joined on 08-30-2008
    • Posts 1
    Hi 1
    I noticed your problem with the Beogram 1200 speed. You can adjust it up/down with
    the thumbwheel low on the left side of  the turntable. You don't have to open anything.
    Look carefully and you will find it.
    Hope this will help
    Sput1
