Latest post 03-26-2008 3:20 PM by beoperson. 1 replies.
Page 1 of 1 (2 items)
  • 02-25-2008 4:51 PM
    BV4 & Beosystem 1 Question...
    Hello, Beoworld...
    I am fairly new to the forum, just starting to get into B & O in the last couple of months.  Have always loved there gear but never indulged in it.  Recently acquired both a BeoVision 4 50" (Item 1895126  Type 8951) as well as a Beosystem 1.
    From my understand in regards to connections highest or best quality starting on top going down would be
    HDMI
    DVI
    RGB (VGA)
    Component
    S-Video
    Composite
    Connection on the BV4...
    AV IN ( R/L RCA Audio, Video RCA, S-Video )
    COMPONENT/RGB IN ( R/L RCA Audio, VD HD Pr/Cr/R Pb/Cb/B Y/G )
    PC IN ( looks like a HD15 SVGA port & a single RCA Audio )
    Serial ( looks like a 9-pin RS-232 standard port)
    In terms of the BeoSystem 1 to BV4 what connection would yeild that highest quality or best connection?
    BeoSystem 1 - RGB (VGA)
    Then for the BV4 would it be the PC IN connection or is that strictly for connecting a computer? or the COMPONENT/RGB IN ( R/L RCA Audio, VD HD Pr/Cr/R Pb/Cb/B Y/G )
    Regards,
    Hiller
    BeoVision 4-50 MkII, BeoSystem 1, Zektor Switch, DTS box, BeoLink Passive, BeoVox Cona, BeoLab 1, BeoLab 3500, BeoLab 6000, BeoLab 4000, BeoLab 4, BeoLab 3000, BeoMedia 1, BeoMaster 5, BeoSystem 3 Type 9621
  • 03-26-2008 3:20 PM In reply to
    Re: BV4 & Beosystem 1 Question...
    BeoSystem 1 has only one output to TV/Projector which is RGB (VGA)
    I use PC IN slot with my Panasonic TH-58PH10UK
    David the BeoPerson
