Latest post 02-25-2008 5:46 PM by krisb. 2 replies.
Page 1 of 1 (3 items)
  • 02-25-2008 3:53 PM
    • krisb
    • Not Ranked
    • Joined on 01-29-2008
    • Athens, Georgia, USA
    • Posts 28
    Beolink 1000 & Beomaster 5500 Loudeness setting
    Hi!
    I just got my Beolink 1000 in the post (the older type with the "reset" button)
    and if I press reset it seems to jump to the pevious owners setting or something.
    Balance is to the right slightly and the treble + bass are up slightly.
    I can turn these off easy but I can't turn the loudness setting off. Where is that?
    Cheers
    Kris
  • 02-25-2008 4:12 PM In reply to
    Re: Beolink 1000 & Beomaster 5500 Loudeness setting
    krisb:
    I believe these are the things you can't permanently fix without a MCP or a later model Beolink 1000 Sad
    Anyway, this setting will probably be cleared (along with all FM presets, etc) if you remove the battery from inside the Beomaster for 10 minutes or so...
    In my 6500 (with the old BL 1000), loudness is the next setting after treble when you keep hitting "sound" (use the up and down arrows to switch on and off). Doesn't that work with the 5500?
    -mika
    -mika
  • 02-25-2008 5:46 PM In reply to
    • krisb
    • Not Ranked
    • Posts 28
    Don't worry! I've got it!
    Just needed to press shift and then "reset"
    Thanks!
    Kris
