Latest post 03-17-2008 4:40 PM by Montecarlo. 3 replies.
Page 1 of 1 (4 items)
  • 02-25-2008 12:26 PM
    Help needed for wiring a TV to B&O beo speakers
    Hi there,
    Can some one provide me the pin out shedule for making up a cable assembly for the following TV to BEO speaker
    I have RCA/Phono connector at the TV end
     The Speaker  has a 5 pin din connection
    I also require the information for making up a lead for my i pod to the speaker.
    It would be a 3.5mm stereo jack plug to a 5 pin din plug
    Chris
  • 02-25-2008 12:43 PM In reply to
    Re: Help needed for wiring a TV to B&O beo speakers
    Have a look at www.beotech.co.uk which has various pin out diagrams. Which B&O speakers are you going to use?
    In fairness though it would be much less hassle to buy a DIN-RCA adapter lead and a 3.5mm-DIN adapter lead from one of the sellers on eBay or similar.
    Regards Graham
  • 03-07-2008 1:34 PM In reply to
    Thanks for the information.
    I am still unclear on the 5 pin din connector. What is the wiring schedule i.e. which one is earth, right in, and left in connections
    1
    2
    3
    4
    5
    Cheers
    Hey if this works then i will sell them myself on Ebay. I am using a gold contact Neutrik din plug, Van Damme oxygen free cable and a gold contact 3.5mm Neutrik jack plug
  • 03-17-2008 4:40 PM In reply to
    aha now i have sorted the pin outs and the lead works great
    You can check out my ebay store at A1 ipod cables
