Latest post 02-26-2008 5:31 AM by ajames. 7 replies.
Page 1 of 1 (8 items)
  • 02-25-2008 8:47 AM
    Avant - Cleaning the Screen
    Does anyone know if there is a way of removing the nti-glare screen in front of the Avant to clean the tube underneath - I did it a while ago on my LX when I first got it and got good results - just wondered if there was a way with the Avant or if it sealed. It's the non-rf 32" version.
    Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
  • 02-25-2008 10:55 AM In reply to
    Re: Avant - Cleaning the Screen
    The procedure is outlined in the service manual which is on this site.
    Regards Graham
  • 02-25-2008 11:41 AM In reply to
    From what I have seen there are no non RF Avant service manuals on this site they are all for the RF versions. Please correct me if I am wrong.
  • 02-25-2008 12:28 PM In reply to
    Quite correct!
    PM me your email address and I'll send you a scan of the page in my manual.
    Regards Graham
  • 02-25-2008 2:41 PM In reply to
    Loosen the two big screw's thats placed in the bottom of the screen, then move the frame up and out. From there you can see what to do.
  • 02-25-2008 4:10 PM In reply to
    Fantastic - thank you - gave it a clean and not much dirt but definetely better.
     Thanks again
  • 02-26-2008 2:51 AM In reply to
    is it vacuum sealed in there ?
    popgear is grate™
  • 02-26-2008 5:31 AM In reply to
    I don't think it's vacume sealed, but there is a seal to stop dirt coming in and it seems to work very well as there was hardly any dirt but cleaning has made a difference.
