Latest post 02-24-2008 10:24 AM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 02-24-2008 7:55 AM
    Setup Problems....
    Hi All, new to the forum and need a little advice...
    I've just got my gear out of storage (they've been there for 4 years) and I know I'm going to have problems linking it all together as last time I ran it as two seperate systems.
    In the living room I have 32" Avant with BeoLab 1 (front) & BeoLab 6000 (rear) & BeoLab 2.  I also have the BeoSound 9000.
    In the bedroom I have the AV 9000 with BeoLab 8000 (front) & BeoLab 4000 (rear) and a BeoSound 3200.
    Then I also have the BeoLab 3500 & BeoLab 2000 elsewhere in the house.
    As far I'm aware, the AV9000 can only be configured as Master but could I configure the Avant as a slave and have it as one system?  Also, if this was possible, would I be able to link the Sky+ to the Avant and still have full control throughout the whole system?
     Thanks in advance.
     Paul.
    I spent a lot of money on booze, birds and fast cars.
    The rest I just squandered.
    George Best
  • 02-24-2008 8:50 AM In reply to
    Re: Setup Problems....
    No. You would have to attach the Sky+ to the AV9000. You will need an STB-C in the AV9000 - they are apparently no longer made though. This is a big problem with the AV9000 - I use mine as a separate system with a second Sky box.
  • 02-24-2008 9:12 AM In reply to
    Thanks for the reply Peter.
    Does the STB-C connect to the back or is it a module that needs to be installed onto the internals?
    Anybody got one for sale...?
    George Best
  • 02-24-2008 10:24 AM In reply to
    It is an internal module. It activates as V.Aux which is not ideal. The Avant works much better with Sky in my opinion.
